Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 03-03-2012, 12:20 PM   #1
Window Trim
Hello,
What would you all do in this situation? I have an old house, things are crooked, not level, not plumb, etc. I had new windows installed and I am putting trim around them now. In this photo, it shows that the drywall sticks out past the window therefore leaving a 1/8" gap between the window and the back of the trim. Now, I could pad it out with a piece of filler but the problem is that some parts of the drywall are flush with the window. Now what? Should I make an outline in the drywall and shave back certain parts?
Smoke is offline   Reply With Quote
Old 03-03-2012, 02:55 PM   #2
Window Trim
For 1/8" I usually am able to score the drywall on the high spots 1/4" inside the width of the casing, so the casing covers it. Chisel this down (some just break it with a hammer, I don't). so it is flush with the window. When you put on your casing it will be slightly angles out and you have to account for this in your mitres.
mae-ling is online now   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
BigJim (03-03-2012)
Old 03-03-2012, 04:04 PM   #3
Window Trim
ya i smash it with a hammer and cut it with a utilty knife, larger then a 1/4" then i'd put a build out
princelake is offline   Reply With Quote
Old 03-03-2012, 04:08 PM   #4
Window Trim
Thank you for your replies, I will try it!
Old 03-03-2012, 04:16 PM   #5
Window Trim
Hard to say from that picture. Looks like more then 1/8 to me.
Is the sheetrock even with or cut back away from the window jambs?
If it is just an 1/8" cutting the paper with a razer knife and tapping the rock to remove some it as suggested has always work for me.
Old 03-03-2012, 04:29 PM   #6
Window Trim
If it is 1/4" and out in some spots and flush in others add 1/8" filler strip. then do as suggested above
crown molding meets window trim sonofthetonsured Carpentry 13 03-19-2011 01:33 PM
window trim bevel HHac8014 Carpentry 8 12-07-2010 09:47 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Arched top window trim jelly Carpentry 5 07-05-2008 04:38 PM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-14-2005 12:59 AM
