Window Trim - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-07-2011, 10:10 AM   #16
TRIM in progress...
Once I tapped off the wood that would still be exposed, I filled the 'crack' from the rough-out cut of the doors/windows with plaster then sanded the plaster BEFORE I removed the tape. I then painted the wall up to the edge of the wood. I painted the trim separately [before I miter cut the trim - seriously, I cut the trim with an x-acto blade]
MsFinnegan is offline   Reply With Quote
Old 10-07-2011, 10:16 AM   #17
finished TRIM
And here is the finished TRIM! More timely, less costly, exactly the look I was going for! [You could use a stained trim if that fits the style of your home better too!] I found that painted the same color as the wall, generally it 'goes away'... especially at night when the sun isn't casting shadows.
I hope all this helped. Let me know if you have any other questions or need details of any photos!
Good Luck!
Old 10-13-2011, 11:31 AM   #18
It should be very straight forward to remove the old trim carefully, and apply new trim in whatever style you desire. I used my already in place colonial trim, and added to it to make it look custom. Cost a lot less, less work, and the results were what I wanted.
25thmustang is offline   Reply With Quote
Old 12-15-2011, 02:13 PM   #19
did you see this??
i'm unsure if it ever made it to our conversation...
Window trim
Old 12-15-2011, 09:06 PM   #20
Rewards Points: 13,774
That narrow trim makes it look like a mobil home.
Another way to soften the look of sheetrock returned jams is to install rounded not 90% outside corners. It's as simple as nailing it up and applying drywall compound like on any corner.
crown molding meets window trim sonofthetonsured Carpentry 13 03-19-2011 12:33 PM
window trim bevel HHac8014 Carpentry 8 12-07-2010 08:47 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Arched top window trim jelly Carpentry 5 07-05-2008 03:38 PM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-13-2005 11:59 PM
