Window Trim - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-09-2011, 08:48 AM   #1
Rewards Points: 77
Window trim
I have a 1959-built ranch home with odd-sized windows trimmed out with the original rounded 2" trim. I painted all if it white, but it still does not look that great.
I was in a friends house and his house is trimmed out with 3" trim on the windows and 4" on the baseboards. I like it, but I am also considering removing all of the trim and just finishing it with sheetrock.
Thoughts?
Thank you
Graham
gjones is offline   Reply With Quote
Old 09-09-2011, 08:55 AM   #2
the Musigician
DangerMouse's Avatar
How about some photos?
DM
Old 09-09-2011, 08:59 AM   #3
Rewards Points: 77
I will take some and post. My digital camera was stolen so I will have to take with my phone so they may not be the best.
Old 09-09-2011, 08:59 AM   #4
Experienced
Jackofall1's Avatar
Not sure how you would finish a window trim off with sheet rock thats would be a new one to me.
You could do 3" wood, either stainable (my preference) or paintable, but you have to be aware that to do trim work you need the proper equipment, at a minimum a good saw.
Mark
Old 09-09-2011, 09:03 AM   #5
DIY staff
Rewards Points: 7,174
You will add a lot of value and enjoyment to your home with upgraded trims and perhaps new interior doors.
Post pictures of the ranch moldings you have now---Original house might be plaster---Skim coating might take car of the old surface.
Old 09-09-2011, 09:04 AM   #6
Rewards Points: 77
Mark,
I have access to any equipment I need as a buddy of mine is a remodeling contractor.
From what I can remember, some of the newer homes I have seen did not have window trim inside. I could be dreaming something up though...
Old 09-09-2011, 09:04 AM   #7
kwikfishron's Avatar
Rewards Points: 1,008
There are all kinds of ways to trim windows and what might look great in one house will look out of place in another.
If you Google "window trim" and look at the images you’ll get endless ideas. If you see something you like you can post it here and we can help you make your window look like the one you chose.
kwikfishron is online now   Reply With Quote
Old 09-09-2011, 09:08 AM   #8
Experienced
Jackofall1's Avatar
Originally Posted by gjones View Post
Mark,
No I have seen windows dressed without the use of casing, but, the wall openning was built with that consideration, as your windows already have casings, it would be more pratical to just replace those.
Mark
Old 09-09-2011, 09:12 AM   #9
Rewards Points: 77
Mark,
That may be what I saw. I may just have to stick with some sort of trim and redo the casings later.
Old 09-09-2011, 09:47 AM   #10
the Musigician
I've seen metal bead edges on windows as well as curved.
Not my preference though. I like hardwood trim.
DM
Old 09-09-2011, 10:12 AM   #11
I've seen it done without any trim. Something like this:
IMO, it's quite a risk since drywall is so susceptible to water. I'd imagine that this setup would also be prone to cracking...
GottaFixIt is offline   Reply With Quote
Old 10-06-2011, 04:32 PM   #12
I have an 80's contemporary home & just had all the window & door trim & baseboards removed! Some I had a plasterer "wrap" with plaster & painted to match the walls (so the paint goes from the walls to the inside of the window sills, leaving just the window trim wood.) This was super expensive.
On other windows & doors I plastered in the gap between the wooden door & window jam (plaster NOT joint compound-too soft) then used a 3/4" x 3/8" wood trim piece to go over the crack. It needs to be covered because as your house heats & cools the walls do shift slightly. I painted the trim to match the walls leaving only the insides if the windows wood (but you could stain the wood too, to match your style). The look is very rich & custom. It's also super easy to cut & install. It will take longer than the old fashioned trim option but it's a trade with expense...sometimes time is money!
Best of luck.
MsFinnegan is offline   Reply With Quote
Old 10-06-2011, 04:34 PM   #13
I'll post a photo if you are interested...let me know.
Old 10-06-2011, 05:59 PM   #14
Rewards Points: 77
I would love to see a few pictures. Thanks!!
Old 10-07-2011, 09:55 AM   #15
3/4" TRIM painted to match the Walls
Here is a photo of the plaster wrapped windows, skylights and doors... this cost a small fortune, but totally worth it for the 'high traffic' rooms...
crown molding meets window trim sonofthetonsured Carpentry 13 03-19-2011 12:33 PM
window trim bevel HHac8014 Carpentry 8 12-07-2010 08:47 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Arched top window trim jelly Carpentry 5 07-05-2008 03:38 PM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-13-2005 11:59 PM
