Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 10-26-2009, 10:49 AM   #1
Default window sash replacement kits?
We need to replace the windows in our 1928 home, 16 in all, starting with about 8 now. We've looked at insert replacement windows but we would lose nearly an inch of glass on each side of the window (ex: Jeld-Wen Siteline EX windows are 3 5/16" from jamb to viewing area, and our current windows are only 2 1/4").
A sash replacement kit seems like a good option: we would certainly get improved performance over our decaying single pane windows, and we wouldn't lose all that viewing area. Our frames seem to be in surprisingly good shape after checking height, width, square, plumb / level, so it seems like we could make these work.
I'm wondering if anyone has experience with these and can you help us with a few questions:
  • How well do they perform compared to old single pane windows? What about compared to an insert replacement window?
  • Any comparison between: Jeld-Wen ZapPack, Jeld-Wen Siteline EX, Marvin Tilt Pac? Any others you would recommend we consider?
  • How does the price for a sash replacement kit compare to the price for an insert replacement window? We're looking at double hung, wood clad, Low E/ argon window with SDL grids, approx 32 x 58.
Thanks for the help!
Jim
jimhome is offline   Reply With Quote
Old 10-27-2009, 08:01 AM   #2
I have only used Marvin tilt-pacs, so i can't speak about the others. CAREFUL measurement of the opening is crucial to a proper fit. Follow the manufacturers recommendation for measuring.
Old 10-27-2009, 10:37 AM   #3
I've been using the Jeld-Wen "custom window" instructions for measurement, which guide you through measuring height in three places, width in three places, level, plumb, square, and twist for the frame. So far the windows have been within their tolerances, which are generally 1/8" of variance.
Even with checking and double checking measurements, I'm still anxious about just how perfect the frames need to be to make this work. Was your experience that the frames need to be "dead on" or will the sash replacements work well even with small deviations?
Have the Marvin Tilt-Pacs worked well for you overall? Any issues with air infiltration or sash movement? When you installed your kits, did you do any extra weather-proofing e.g. around the jamb liner or at the sill?
Thanks so much for the help.
Jim
Old 10-28-2009, 07:59 AM   #4
I have installed quite a few Marvin tilt-pacs over the years, including in my own house(20+ yrs ago). I have had few calls from customers, indicating they are satisfied. I only have one window that has leakage issues, probably due to bad measurements on my part. Marvin said to caulk the jamb liner at the sill, which is what I did.
Old 10-28-2009, 08:27 AM   #5
Marvin tilt pac all the way!
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 11-02-2009, 02:48 PM   #6
Heritage Restoration
Find a Heritage Window Restorationist.
It will shock you how efficient the old windows are compared to modern windows....once you get them back to the way they were in the 1920's
Skuce is offline   Reply With Quote
More On This Topic
Hi. I am David Belch with All Bright Restoration Services. Today Im with Expert Village to show you how to install windows. OK several reasons that you want to replace your window and that being infiltration. OK these windows all they have, they have no... Read More »
Basic Parts of a Window
Basic Parts of a Window by Expert Village
Hi, I'm David Belch with AllBright Restoration Services. Today I'm with Expert Village to show you how to install windows. What we're going to talk about right now is the components of a window. Ok, what we have here, this is called a sloping sill. It?s... Read More »
On behalf of Expert Village, my name is Gregg Tauriello. I'm from Sweet 16 Studio, and I'm here to talk to you about soundproofing for a recording studio. Okay, here we are at the exterior window. I just wanted to mention to you that if you skimp on your... Read More »
If you find yourself creating a publication repeatedly, then you need to create a template instead. Templates are essentially a master pattern that you work from in creating publications. In the desktop publishing software, Microsoft Publisher, templates... Read More »
How to Remove Old Windows
How to Remove Old Windows by Expert Village
Hi I am David Belch with Expert Village to show you how to install windows. Now I am going to remove a window and the first thing I am going to do is to remove the stops. The blind stops are again nailed behind the brick mold so they have to be what they... Read More »
Replacement Window with nailing fin mjbcable Building & Construction 0 09-15-2009 03:40 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 07:11 PM
How to install Replacement window in 2x4 frame? BFD8 Remodeling 18 01-07-2009 01:56 PM
Replacing window sash with rotten bottom jandrew Carpentry 3 08-31-2008 06:02 PM
latest problem...window replacement gone_fishing Remodeling 10 02-11-2008 10:24 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
