Window Replacement - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-26-2010, 07:46 AM   #1
window replacement
What is the best way to cut out my existing window to put in a new vinyl replacement window?
donnieb5213 is offline   Reply With Quote
Old 06-26-2010, 09:24 AM   #2
Ours didn't require any cutting . There was a wood trim piece against the window frame sides on the inside and on the outside. I removed the inside trim, removed screws holding in the old window and they came right out. Ran a bead of silicone between the outside piece and the new window, put window in and shimmed it square and level. Another bead of spray foam made for windows around the edge from the inside and then put the trim back on. No more drafts blowing in all winter and it only took 20 minutes per window from start to finish.
Easiest DIY project I ever attempted.
Old 06-26-2010, 10:07 AM   #3
kwikfishron's Avatar
Rewards Points: 586
It all depends on what you have in there now.
Does your new window have nail fins?
Post a picture if you can.
kwikfishron is offline   Reply With Quote
Changing Size of Replacement Window joside Remodeling 10 05-30-2012 04:46 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
Replacement Window Installation Cost asr1715 Remodeling 1 02-08-2010 10:26 AM
window sash replacement kits? jimhome Remodeling 5 11-02-2009 12:48 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
