-   -   Window putty won't dry - wet atmosphere (http://www.diychatroom.com/f15/window-putty-wont-dry-wet-atmosphere-61097/)
DIYNovice0 01-05-2010 06:03 PM
I realise now that it wasn't the greatest idea that we've had but we decided to replace the putty on the interior of some windows recently.
The reason that it wasn't such a great idea is that it is winter here now and the windows, being single paned, get a lot of condensation! The water is dripping down the windows into the new putty and making it wetter than it was when we started!
We put the putty in 2 days ago and it is showing no signs of drying out. It is now more liquid than it was when it went in.
We could remove the wet putty but that would leave the windows unprotected and it is a long time till the summer!
I wipe down the windows when I get up in the morning but half an hour later they are dripping again. I don't think that I can keep the windows dry and can't be wiping them down all the time.
Short of getting brand new windows and frames, is there anything that anyone can suggest?!
I'd be very grateful for any help. We are planning to rent out the place soon so really need to get this problem sorted out!
And, before you say it, I know that we were very stupid!
Thanks in advance
chrisn 01-06-2010 04:59 AM
1 Attachment(s)
By putty, do you mean window glazing?
DIYNovice0 01-06-2010 05:36 AM
Hi!
On the tube it describes it as acrylic polymer glaziers putty.
The one I have is made by Unibond.
stuart45 01-06-2010 08:40 AM
If you use the old fashioned linseed oil putty, it stays soft for about a month. It doesn't mix with water so it won't get wetter. You can't paint it for at least a fortnight, or when it skins over.
I've never used the modern putty, but it is probably similar.
chrisn 01-07-2010 05:41 AM
Originally Posted by DIYNovice0 (Post 377561)
Hi!
I would remove that and replace with the real glaze that I posted
Red Squirrel 01-08-2010 12:47 AM
Try to point a convection heater or a high wattage lamp at it, it might help. Just make sure it's fire safe and don't leave it unattended. Also remove any drapes for now as they'll trap moisture in.
DIYNovice0 01-10-2010 04:34 PM
Thanks everyone!
Thanks for all your replies.
I think that I will have to start again, with an oil-based putty.
Better get to work...!
Thurman 01-10-2010 06:11 PM
Glazing windows was an artform that my Granddad taught me years ago, and I've done many since then. When you stated "On the tube", that was all I needed to read. I, ME, do not like the newer products in the tubes-and I have given them a decent trial. As "chrisn" stated, IMO, you will really need "window glazing" such as the DAP 33 product. Window glazing is not something that I feel is easily learned in one trial either, proper glazing take practice to form proper seals, and is well worth it. As stated, good glazing contains Linseed Oils and does not dry out soon. I would remove the material used, and obtain some DAP 33 and start learning how to glaze windows. Good Luck, David
Penczak 01-10-2010 08:47 PM
I'll add if you have never done it it is very time consuming. I learned the hard way, too.
william duffer 02-13-2010 03:02 AM
I had a problem with some leaky windows this winter, i put some kitchen and bath caulk on and will deal with cleaning and redoing it right when it gets warm. It dried pretty fast. no leaks.
DangerMouse 02-13-2010 06:10 AM
you need to stop the moisture from FORMING to begin with.
I'd dry the windows off, then put some sheet plastic (window weatherization kit) around the frame to make a dead air zone.
when the weather breaks, THEN you can putty and it'll dry just fine. although the double seal is still preferable for the next year as it helps hold in your HEAT too! I'd also consider double-paned windows being installed.
DM
Skuce 02-14-2010 10:21 AM
Everything you'll ever need to know about how to make Windows and Putty good.
http://historichomeworks.com/forum/v...06d3a7ada51777
tpolk 02-14-2010 10:28 AM
why is the putty on the inside
12penny 02-15-2010 09:02 AM
I was thinking the same thing since the opening post, but thought it may be a window style I'm not familiar with. If the windows are glazed properly there will be a small amount of putty on the inside. This is what the glass is bedded in. If you need to re-do it then the window pane should come out, all the old putty removed, lightly sand, prime and reglaze.
Skuce 02-23-2010 01:40 AM
The only time there should be putty on the inside is the side/transom lights on Georgian/Neo-Classical/etc front entrances. Show off the cool muntin mouldings to your guests coming to the door.
Otherwise the putty is to the outside so the people in the house get to view the cool muntin mouldings.
Either way...you should not be using anything that comes in a Tube to do windows.
Knife grade, natural oil putty is the only way to go. It's been used for at least 700 years. That's not a bad track record for a product if you ask me.
