-   -   Window pane replacement help (http://www.diychatroom.com/f15/window-pane-replacement-help-36311/)
dgbehrends 01-19-2009 12:00 AM
Hi and thanks for reading,
My house has enerpro double pane windows. They were put in either in late 2003 or early 2004 when the house was built. I bought the house in the fall of 2007. When I moved in one of the windows had a cloudiness in the window. I contacted the builder who said it was still under warrenty and gave me enerpro's contact information. Hal's millwork out of Minneapolis. They came out to replace the window once but brought the wrong sized window. Measure twice cut once comes to mind. I guess they only measured once. For the next 9 months they have not returned my phone calls about getting this window replaced. I'm very frustrated and will most likely need to install it myself. Now to my questions:
Are there any good guides out there for removing and installing double pain windows or can someone explain to me the procedure? The vinyl frames still look new so all I need to replace is the pane. Do I need any special tools? At this point I would prefer not to deal with enerpro at all, so can I go with any type/manufacturer of window pane? I suppose it has to be double pane and not triple.
Tom Struble 01-19-2009 12:06 AM
keep calling tell them your to sue :thumbsup:
dgbehrends 01-19-2009 01:10 AM
I've already told them that if they didn't call me back I would report them to the BBB. I guess they weren't too worried about that. I'm not big on making threats or getting lawyers involved though.:thumbdown:
Tom Struble 01-19-2009 01:29 AM
you could just pull the sash out and bring it to a local glass company
wrangler 01-19-2009 07:00 AM
I would try to contact enerpro as well. If Hal's Millwork is having problems or even out of business, Enerpro may have another contractor nearby that can help you. If not, and the window tilts is, it is really easy to remove and you can take it to a glass company. Tilt the wildow down to 90 degrees, then lift up on either side to release it from the balance. Then you can place a piece of foam board, plywood, or cardboard into the opening during repair. If not, then it is a bit harder to remove the fixed pane of glass, and would really be best to be done by a glass company as you have to remove the glazing bead (preferrably without destrying it so that it can be reused) , then the IGU (the glass pack) wich is best done with a deglazing tool to avoid breaking the glass.
Since they are still under warranty, I would go with the Enerpro route first if possible.
EDIT: Just searched and found out that Hal's IS the manufacturer for Enerpro windows, so if they are not returning phone calls, I guess that is not an option.
Just Bill 01-19-2009 07:07 AM
Not sure why they got it wrong the first time. Most manufacturers put stickers on each sash with all the details for that sash, when made, dimensions, type glass, grids, etc. Some cheapy manufacturers don't do that, not sure what yours are. If you can't get satisfaction from the installer, go directly to the manufacturer. Glass is usually guaranteed for at least 10 yrs for the problem you have, failed seal. Most are 20 yrs to life. Which is what some manufacturers should get for their cheap products.
dgbehrends 01-19-2009 10:33 AM
I should mention that these are crank out casement windows. I believe that Wrangler is correct. My googling also led me to believe that Hal's is both the manufacturer and installer. What they brought last time was just the glass pack (which I was calling the window pane). So it would be a matter of replacing the glass back in a vinyl window. It sounds like a would need a special tool and that it might take a skilled hand to avoid destroying the gasket. The builder gave me the warranty certificate and they have a 10 year warranty, assuming Hal's stays in business, which given the current economic environment is a big question mark. My opinion of these windows is not very high.
Tom Struble 01-19-2009 12:42 PM
there's an old saying ''The squeaky wheel gets the grease''You paid for a warranty you shouldnt give up so easy.Call,Email Write make a real pest of yourself find out who owns these companies contact them direct if you can.But if your not going to do that just call a local glass company thats been around a long time and have them fix it for you :thumbsup:
if i install a widow and its defective my window manufacture sends me a whole new sash
Brik 01-19-2009 12:57 PM
if you are going to replace it yourself check out this guide and the accompanying podcast..
http://www.handyguyspodcast.com/32/e...7-broken-glass
Good luck and let us know how you make out.
jogr 01-19-2009 01:02 PM
Try discussing it with the builder. The builder should be doing the legwork on this.
If no resolution definitely follow up with BBB. Do any of your local news stations have a consumer guy that does stories about local consumer issues with businesses? Having a news crew show up usually provides incentive for a business to fix things to make the cameras go away.
dgbehrends 04-16-2009 04:04 PM
Out of Business
It had been about 4-5 months since I had last tried calling the maker of Enerpro Windows, Hals Millwork, and this time the phone was disconnected. I called a local distributor and he confirmed that they had gone out of business. So now I'll have to have a new low-e glass pack made by a local glass company.
dgbehrends 04-30-2009 04:01 PM
Work is complete and window is as good as new
I contacted and hired out a local glass company to replace the window. Turns out they have been doing many of the enerpro window replacements in my area. They were very reasonable and charged $140 for a 2x5 casement window pane including install,tax, everything. The window has a 20year warranty. No more fogginess, I'm as happy as a clam :)
HomeSealed 04-30-2009 05:38 PM
I'd send a bill to Hal's.
dgbehrends 04-30-2009 10:57 PM
If I knew where to send it to I would. They are now out of business. Most likely they will reform as a new entity. This is a common theme in the builder community is it not?
dgbehrends 11-17-2009 01:06 AM
I contacted and hired out a local glass company to replace the window. Turns out they have been doing many of the enerpro window replacements in my area. They were very reasonable and charged $140 for a 2x5 casement window pane including install,tax, everything. The window has a 20year warranty. No more fogginess, I'm as happy as a clam http://forum.doityourself.com/images/smilies/smile.gif
