Window Measurements - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-19-2010, 07:29 PM   #1
Apprentice
UpComingBuilder's Avatar
Window Measurements
Where do you get the window measurements if you need new windows?
Do you meausre from inside the jambs then add what both the jambs are; like 3/4 jambs, you would add 1 1/2''?
Same with the measurements for the height of the window?
I am going to install 3 windows in my house, all 3 are double hung and are the same measurement.
I have all the casing off 1 window, but on the bottom jamb, it is 1'' thick. And it looks like there is another piece under it that may go to the sill. This piece is about 1/4'' thick, it looks like it follows the window sills slope.
Also, where the top jamb meets the side jambs; the side jambs go a little over the top jamb. Do I meausre from the top of the side jamb? Or where the 2 jambs connect?
Sorry if this is confusing..
>>SooN<<
UpComingBuilder is offline   Reply With Quote
Old 03-19-2010, 07:31 PM   #2
I pull off all of the casings & measure the RO -rough opening- to the studs
Then I pick a window based on the measured RO
At my house that meant buying larger (wider) windows as there were pockets on each side that had sash weights from old single pain windows
Old 03-19-2010, 10:15 PM   #3
Registered User
Rewards Points: 5,232
A picture would help.
http://www.jeffgreefwoodworking.com/...Hng/index.html
Be safe, Gary
Gary in WA is online now   Reply With Quote
Old 03-21-2010, 09:13 AM   #4
Apprentice
Ok, I will get a picture. The plaster covers the studs though.
>>SooN<<
Old 03-21-2010, 01:20 PM   #5
Apprentice
I can't figure out how to upload pictures. It says upload failed every time i try it
>>SooN<<
Old 03-21-2010, 01:49 PM   #6
Apprentice
From outside jamb to outside jamb the window measures
2'-9 11/16'' x 4'-5 1/4''
Those measurements seem weird if I were to order them like that. There not custom at all, just double hung.
My instructor said measure with the jambs and it should fit right into place. He said you wont even need shims.
The RO's are:
34 7/8'' x 57 1/8'' or 2'-10 7/8'' x 4'- 9 1/8''
>>SooN<<
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 09:39 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 11:47 AM
