Window Jamb Extensions - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-07-2010, 12:21 PM   #1
Window jamb extensions
I bought an older house last year and were slowly remodeling it. We have block walls with no insulation which I understand is common. I'm going to remove exterior walls to insulate.
If I leave the furring strips on the walls I can only use roughly 1" foam board which isn't really enough R-Value right?
If I stud up the walls to put proper insulation in, what are my options for the existing vinyl windows? Am I able to remove the existing jambs and replace them with wood?
What about our bow window? Can I just add pieces of wood fill the lines with wood filler then re-stain it all?
Our Entry door we'll eventually replace it but a fix for the mean time?
Any help is appreciated have a Blessed Day=)
wmjdr is offline   Reply With Quote
Old 06-07-2010, 02:32 PM   #2
DIY staff
Rewards Points: 7,174
Are you going to leave the windows in place? Extend the out side jambs?
Or remove the windows and add jamb extenders to the inside?
Let us know--Also--If you can post a picture or two it will help you get a better answer.--Mike--
Old 06-07-2010, 02:41 PM   #3
The windows are staying in place, I was thinking about extending the existing jambs, I just wasn't sure if I could take out the existing jambs while leaving the window in place.
Probably won't have any pictures, sorry.
Old 06-07-2010, 03:09 PM   #4
DIY staff
That's O.K.--I never figured out how to post pictures my self.
I'm not sure how to guide you on that on--I'm an inside trim guy--
Hopefully Tom Struble,Jhaslip or one of the siding pros will be home from work soon.--Mike--
Old 06-07-2010, 03:17 PM   #5
that's what I'd like advice on. I'll be adding depth on the inside of the house and was curious as to what my options were for the existing vinyl windows, without removing/replacing them. If I lost my intentions in translation I apologize
Old 06-07-2010, 06:46 PM   #6
kwikfishron's Avatar
Rewards Points: 210
I’m totally confused.
“I'm going to remove exterior walls to insulate”.
“If I leave the furring strips on the walls”
The walls you just removed?
“If I stud up the walls to put proper insulation in”
I have to assume your not removing your block walls, do you want to stud up the outside? If so, how thick?
This is one were pictures are needed (for me anyway). I know you told Mike you can’t do pic’s. but maybe a friend can help you out.
kwikfishron is online now   Reply With Quote
Old 06-07-2010, 08:07 PM   #7
Tom Struble's Avatar
Rewards Points: 2,002
sounds like he means remove the exterior siding and either leave the existing 1x furring or use a 2x on the flat?for more insulation? i would much prefer to have most of the extension jamb in the inside of the house so the units aren't too sunken in,they can get hard to weather proof the deeper they are
Tom Struble is offline   Reply With Quote
Old 06-07-2010, 08:50 PM   #8
Concrete & Masonry
Rewards Points: 530
I guess this is fairly confusing, but I read it as he's just gutting the interior of the outside walls, not the interior walls. I don't think he's touching the outside at all.
All I can say is use as much insulation as you can now, as energy will never get cheaper, nor will there be a better time to install it.
I'd also search around your area for a contractor that can insulate the block cavities with "Core Bond" or the like. It only adds R5 or so, but it doesn't take away any more interior space.
On edit, I would either add to the existing ext. jambs with a small reveal, or return the drywall to the window on 3 sides, with a stool at the bottom. You'd probably want to use a j-channel/drywall reciever at the windows as well.
I can't say that I really like the DW returns personally, but it's your call.
jomama45 is offline   Reply With Quote
Tags
entry door , jamb , jamb extensions , windows
Defog window recap greenmax General DIY Discussions 4 05-07-2010 06:00 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Window Jamb Extensions Tom5151 Carpentry 27 09-25-2009 10:40 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Window Jamb question groundtrac Carpentry 7 11-23-2008 09:09 PM
