Window Installation Advice - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-11-2010, 05:24 PM   #1
Rewards Points: 150
Window installation advice
This will be my first time installing a window. We picked up a nice almost new window at Habitat for Humanity for a good price that does not have the nailing fins on the outside. Do I make my own or is there some way to install the window without this flange?
I will be removing two larger old windows and dropping in this newer smaller window so I can fit in a shower for my bathroom rehab. I will obviously have to build my own rough opening.
I would appreciate any other advice and possible Web DIY window install videos any of you know of. Thanks in advance for the help.
Cossack is offline   Reply With Quote
Old 04-11-2010, 06:08 PM   #2
if you know window fabricator you can prob get fins. lumber yard or window place may help with pics
The older I get the better I was
Old 04-12-2010, 06:37 AM   #3
Vinyl or wood?? As suggested, finding a fin would make things easier, and it properly locates the window in the opening. Without a fin, you can nail a stop on the opening, and install screws thru the sides.
I assume you have a proper header for the opening??
Old 04-13-2010, 12:14 PM   #4
Rewards Points: 150
The exterior of the window is vinyl and the inside is wood. I thought I would have to attach some frame to the window, but you seem to be saying I can attach somehing to the frame.
Old 04-13-2010, 12:41 PM   #5
Rewards Points: 150
Second view
Old 04-15-2010, 04:01 PM   #6
Rewards Points: 150
This is my first window install. Can anyone tell me how to install the above pictured window without the nail fins? Thanks
Old 04-16-2010, 12:17 AM   #7
Tom Struble's Avatar
Rewards Points: 2,002
you can get the fins from any Andersen distributor
Tom Struble is offline   Reply With Quote
Old 04-16-2010, 01:44 AM   #8
jlhaslip's Avatar
Rewards Points: 1,538
Is there room for a brick mold where the 'nailing flange' meets the sheathing?
Might need to custom build the brick mold to fit the space you have available on the outside of the wall.
Use a drip edge flashing above.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
Retrofit Window Installation typerr Remodeling 4 10-28-2009 11:47 AM
take a look at this tiny gap in window installation, how to take care of it ? heydade General DIY Discussions 5 10-11-2009 10:33 AM
Window well installation gruntman Building & Construction 6 09-26-2009 05:54 PM
