Window Installation - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-16-2010, 04:15 PM   #1
window installation
how do i water seal my window
fracisco flores is offline   Reply With Quote
Old 09-17-2010, 07:13 AM   #2
Assuming a window with a nailing fin.........caulk under the nailing fin(I like siliconized latex or similar, not silicone). Use flashing tape(adhesive back bitument or similar), tape the bottom, then the sides, install the top metal flashing, then tape over that, housewrap over all of it.
Old 09-17-2010, 11:01 AM   #3
Registered User
Rewards Points: 5,216
http://docs.google.com/viewer?a=v&q=...WrZBbBZoIUXgxw
http://www.finehomebuilding.com/how-...x?nterms=63740
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
DangerMouse (09-17-2010)
Old 09-17-2010, 11:11 AM   #4
the Musigician
DangerMouse's Avatar
You just gotta love gravity, you know?
Thanks for those links, Gary!
DM
Old 09-17-2010, 12:22 PM   #5
kwikfishron's Avatar
Rewards Points: 186
Make sure the house wrap goes underneath the lower nail flange of the window, not over.
A critical step that gets missed way to often.
kwikfishron is online now   Reply With Quote
Window Installation Questions cumak Building & Construction 0 05-05-2010 01:22 PM
Window installation advice Cossack Remodeling 7 04-16-2010 02:44 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Window Installation Guide Pondo13 Building & Construction 1 07-18-2008 06:49 AM
Window installation cost only. Changeling Building & Construction 18 06-30-2008 03:01 PM
