Window Inserts Vs. Sash Replacement Kits - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-25-2010, 08:34 AM   #1
Window inserts vs. sash replacement kits
I am considering replacing some of my old windows. I've been looking at the Zap kit from Jeld-Wen. It seems to me if the existing window frame is square, then these kits install faster and give more glass space than a pocket insert. Am I missing something? Is there an advantage to pocket insert replacements versus the sash kits? Thanks.
aejamison is offline   Reply With Quote
Old 04-28-2010, 03:19 PM   #2
Remodeling Contractor
I'm a contractor. In my opinion, stay away from the sash kits. They are a temporary bandaid. Every one I have ever installed has had one issue or another. Thats why I won't even touch them anymore except to throw them in a dumpster. They are crap. Period.
eisert is offline   Reply With Quote
Old 04-28-2010, 11:07 PM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 710
I agree... For one, existing openings are NEVER perfectly square, secondly, sash kits leak air like a sieve. Your better off getting a quality storm window compared to a sash kit imo, but even that doesn't offer much cost savings compared to a mid-grade replacement window.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 04-29-2010, 07:36 AM   #4
Thanks for your replies - all the feedback I've gotten has been somewhat negative on the sash kits, so I think I'll go with the insert instead.
ajamison is offline   Reply With Quote
Old 04-29-2010, 07:38 AM   #5
I have older Marvin tilt-pacs in my house and have installed many. They do not tilt easily, but I suspect that has been fixed over the years. The jamb liners tend to compress and the top sash will not stay up when unlocked. Other than that, I like them. I will concede that properly installed(air gaps insulated) pocket windows are probably more energy efficient.
Old 04-30-2010, 01:46 AM   #6
Heritage Restoration
how "old" are the windows you are taking out?
Skuce is offline   Reply With Quote
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 07:37 AM
Replacement Window Installation Cost asr1715 Remodeling 1 02-08-2010 11:26 AM
window sash replacement kits? jimhome Remodeling 5 11-02-2009 01:48 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
How to install Replacement window in 2x4 frame? BFD8 Remodeling 18 01-07-2009 12:56 PM
