Window In Foundation - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-15-2011, 10:35 AM   #1
window in foundation
i have a basement room that does not have a window, can i build one?
razco is offline   Reply With Quote
Old 02-15-2011, 10:40 AM   #2
window
i need to build a window in a roon that is located in the basement.
is this possible?
Old 02-15-2011, 02:13 PM   #3
yes, there is a space, im guessing for the outside i will have to move some dirt around, but is it possible to get a window placed in an already existing foundation?
Old 02-15-2011, 08:38 PM   #4
Registered User
Rewards Points: 526
Yes, it is possible. Call your local Building Department and explain the situation to them, go from there... Permit may/not be needed, yes- if an egress window from the basement or sleeping room (bedroom). Dig out the required area and add appropriate window well material for the depth. Then hire a concrete cutting service to remove the section and chop it into manageable pieces or a General Contractor. Install a waterproofed pressure treated window rough-opening box with caulking and correct fasteners. Add the window with proper flashing and fasten correctly. We can walk you through any problems but you should research it first.
Gary
Old 02-15-2011, 09:22 PM   #5
Rewards Points: 978
i have a window in my foundation wall right now. its not something you want to tackle lightly. if you dont do it correctly it will give you a lot of headache
federer is offline   Reply With Quote
Old 02-15-2011, 10:01 PM   #6
Rewards Points: 5,336
You can build the window, but it's unlikely you can install it.
Ron
Defog window recap greenmax General DIY Discussions 4 05-07-2010 05:00 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Basement window recessed in foundation Freaka Building & Construction 4 11-09-2008 06:15 PM
Replacing a window in a foundation wall? Marlin Carpentry 14 11-04-2007 09:21 AM
