#1 |
Window Flashing with Felt Siding
Installed new pvc nail fin sliders into ro. The stucco guys just finished wrapping the wall that has the new sliders. The first layer is Tyvek, then 2 sheets of heavy felt - I believe 30 lb. They did not tape the tyvek to the window frames/fins. They said they normally do not do that. Tyvek and felt paper were stapled to the studs and just lay o the wind nail fins. After much internet research it seems that taping the tyvek to the window jams would have been a good thing. Now that all the lathing is up and the tyvek is hidden behind the 2 ply felt paper - is it a good idea to tape the felt paper to the window jams? Should I use Jiffy Seal as its asphalt based? Seems like this would provide another barrier? Live in Sacramento area. Gets hot and rarely below freezing. Lots of winter rain.
Thank you. |
#2 |
don't tape the bottom window flange,hopefully you installed flashing to the rough sill framing
| Display Modes | |
| Window Leak: Flashing or Window? | lverma | Building & Construction | 16 | 08-31-2010 01:46 PM |
| Window Flashing with Metal Siding | vtboy51 | Building & Construction | 5 | 02-15-2010 06:00 PM |
| Vinyl siding corner posts and flashing on dormers | rhastler | Building & Construction | 7 | 06-05-2009 11:08 PM |
| Problem with window and everything around it | malfunction | Building & Construction | 3 | 05-26-2009 06:11 PM |
| Window Replacement and siding over T-111 and thick felt board | Badger Hill | Building & Construction | 4 | 05-04-2009 09:27 PM |
