Window In Bathroom, Or Not? - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Closed Thread
Old 07-07-2007, 04:51 AM   #16
Originally Posted by johnny331 View Post
I'm replacing all the windows in my house. I am debating on whether at all to put a window in my bathroom. The bath is about 8x8, pretty small.
I hear a lot around here on how windows and showers just don't mix.
If I do put one in, it will sit right in the shower.
Anyone have any input? Do you have a bathroom without a window, is it like a dungeon?
Here's a sketch of my layout (not to scale of course). Any comments?
I dont have one in my bathroom, but having one in the bath , helps to prevent moisture builb-up
Last edited by Ron The Plumber; 07-07-2007 at 10:45 AM. Reason: Removed link from thread
rk_king2004 is offline
Old 08-14-2007, 03:03 PM   #17
montaillou's Avatar
Put in clear glass block then. Still get the view, avoids the problems of a normal window - which I would agree with everyone else is just a headache. Glass block comes in big sizes up to 12"x12". I was looking at a glass block site and noticed that there's a clear, solid glass block, it appears to greatly minimize the borders one would normally see in a standard block.
Here's a link to the image, I don't have an opinion about the supplier, it's just one I found: http://www.seattleglassblock.com/ima...k_premiere.jpg
montaillou is offline
Old 08-10-2010, 01:06 PM   #18
Talking
HELLO ANY ONE THERE?...U NEED TO AIR OUT THE BATHROOM ONCE IN A WHILE!! A WINDOW IS A DEFENATE MUST.. ALL THE AIR FRESHENERS IN THE WORLD WONT COVER UP THE INTOXICATING SMELL.. OF WELL YOU KNOW>....to even consider not having any windows is the worst idea, the house i live in now has no windows in the bathrooms.. its very univiteing...bathrooms with out windows are disgusting...nothing will replace the fresher air that needs to comeing to the house... the list goes on.
[/quote]
FJCRUIZ is offline
Old 08-10-2010, 01:40 PM   #19
fabrk8r
fabrk8r's Avatar
First of all this thread is 3 years old, so hopefully the OP has his BR done by now.
Secondly FJCRUIZ, there is a product you can buy and install that is called an "exhaust fan"...a neat little item that gets rid of odors and excess humidity without the need for a window. It works really well in the wintertime in Ohio and Downeast Maine too, as opposed to an open window.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline
Closed Thread
Code requirement to replace bathroom window. Rem8 Building & Construction 5 06-16-2008 02:57 PM
cutting brick to add window in bathroom DoubleD07 Building & Construction 14 08-07-2007 02:05 AM
Second level / attic bathroom size moneymgmt General DIY Discussions 2 05-02-2007 07:32 AM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 04:49 AM
