Window In Bathroom, Or Not? - Remodeling - DIY Chatroom Home Improvement Forum
Closed Thread
Old 06-19-2007, 09:19 PM   #1
weekend warrior
Rewards Points: 150
window in bathroom, or not?
I'm replacing all the windows in my house. I am debating on whether at all to put a window in my bathroom. The bath is about 8x8, pretty small.
I hear a lot around here on how windows and showers just don't mix.
If I do put one in, it will sit right in the shower.
Anyone have any input? Do you have a bathroom without a window, is it like a dungeon?
Here's a sketch of my layout (not to scale of course). Any comments?
johnny331 is offline
Old 06-19-2007, 09:50 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
I have 2 baths. One with a window, and the other without.
I have many lights in the bath without the window, and not as many lights in the other. I don't know about putting a window in the shower. I think that it may cause problems later on.
jbfan is online now
Old 06-20-2007, 04:51 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Don't do it.
Do you have a bathroom without a window, is it like a dungeon?.....
Many, many homes and condominiums have bathrooms without windows. As stated, the key is good lighting...
- Build Well -
AtlanticWBConst. is offline
Old 06-20-2007, 07:42 AM   #4
Rewards Points: 5,336
This looks like a ranch. Why don't you put in a motorized skylight?
Ron
Ron6519 is offline
Old 06-20-2007, 04:31 PM   #5
weekend warrior
Rewards Points: 150
thanks, you've reassured me to just not put a window in... now I won't have to buy another one either.
I'll look into a skylight. I just had my roof redone, and I hate the idea of cutting into it. Maybe I'll settle for good 'ol artificial lighting.
Old 06-20-2007, 07:29 PM   #6
Eibwen
I have a bath with a window but have added an exhaust fan. Nobody opens a bath window in the winter or summer and the key is exhausting the moisture to the outside. Most people keep a bath window covered with shades anyway. I wouldnt add a window in the shower area just to have one there. Lotta problems could develop down the road.
Add some extra lights to make it bright and call it good.
Sammy is offline
Old 06-21-2007, 09:10 AM   #7
Rewards Points: 774
I agree. I would not add one either. However, if you must or you don't have a choice in placing window in a shower, I have seen it work. You could always go with a vinyl window and pvc trim, to ensure water resistance. My brother rents an older house with this issure. Instead of a curtain, he added a clear vinyl shower curtain liner to cover the window from the shower. It works, but you probably do not want to go down that road.
I have a 6x9 bathroom with no window, and lighting is definately key.
cibula11 is offline
Old 06-21-2007, 12:28 PM   #8
I'd like to hear other ideas on how to make a window inside a shower work. We'd like to do this in our next bathroom remodel, if it's not too horrible. The window could be fixed if that makes things easier.
NateHanson is offline
Old 06-21-2007, 01:48 PM   #9
(the original)
Rewards Points: 756
Glass block works great if you just want to let in some natural light and avoid the issues associated with an actual window.
ratherbefishin' is offline
Old 06-21-2007, 02:32 PM   #10
We'd be looking for the view, so we want a clear window in the shower.
Old 06-21-2007, 03:43 PM   #11
(the original)
Rewards Points: 756
Nate, Cibula11 has that nailed with the vinyl window and pvc trim. If your enclosure is tiled, you can trim with matching tile. Either way, seal well around the window with silicone before trimming and slope the inside sill slightly so it drains into the shower.
Old 06-21-2007, 05:03 PM   #12
Rewards Points: 150
I put the window back into the shower after replacing the rotted exterior wall of my house that resulted from the old window which apparently leaked pretty bad. I used a standard vinyl window with plenty of caulk and hardiboard tilebacker. I then tiled all the way around the window and sloped the windowsill to drain water and to keep certain people from putting shampoo, soap, and other things on the sill that would keep water from draining. That was almost two years ago. Since then I've sealed the tile twice with a quality sealant, allowing it to penetrate the grout around the window and filled a few minor cracks around the sides with caulk. I think that as long as I maintain the grout and keep sealing it occasionally it should be fine, of course I'll never know until I take the whole thing apart in 10+ years!
billinak is offline
Old 06-21-2007, 07:56 PM   #13
Eibwen
Porthole Matey! Arrrrrrrr!
If you really want a waterproof window... Get an old porthole and frame it in!
Sammy is offline
Old 06-21-2007, 09:15 PM   #14
weekend warrior
Rewards Points: 150
your neighbors will be looking for the view too with a clean shower window
Old 06-22-2007, 06:50 AM   #15
No neighbors here, city-boy.
The only one's peaking at us are the seals and eagles (oh, and that pervert who kayaks by wearing camos, with a really long camera).
Closed Thread
Code requirement to replace bathroom window. Rem8 Building & Construction 5 06-16-2008 02:57 PM
cutting brick to add window in bathroom DoubleD07 Building & Construction 14 08-07-2007 02:05 AM
Second level / attic bathroom size moneymgmt General DIY Discussions 2 05-02-2007 07:32 AM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 04:49 AM
