Will Thinset Stick To Premix Joint Compound? - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-12-2013, 07:30 PM   #1
Rewards Points: 150
Will thinset stick to premix joint compound?
The seam where my cement board meets up against drywall I used premixed joint compound. Some of the compound is where tile will be, it probably wont be getting a lot of moisture, will thinset adhere to premix joint compound?
Arsinek is offline   Reply With Quote
Old 06-12-2013, 08:04 PM   #2
DIY staff
Rewards Points: 7,174
yes it will stick just fine----
Old 06-12-2013, 08:05 PM   #3
Rewards Points: 12
I would prime the joint compound first. The moisture in the thinset could dissolve the compound.
Dan
djlandkpl is offline   Reply With Quote
The Following User Says Thank You to djlandkpl For This Useful Post:
oh'mike (06-12-2013)
Old 06-12-2013, 10:53 PM   #4
Rewards Points: 940
Tell me something that thinset will not adhere to. The problem is, will what it is sticking to keep sticking to what it is sticking to?
In other words, will the joint compound remain sticking, or will it act like Pam when you spray it on a pan?
cleveman is offline   Reply With Quote
Old 06-12-2013, 11:02 PM   #5
DIY staff
This is one more dilemma avoided if you waterproof the board with Redguard or Hydroban before tiling.
Old 06-13-2013, 07:49 PM   #6
Rewards Points: 150
Well, I do have some of that stuff. Can you put it over joint compound? Again though this is in an area that at most might get a few specs of water when someone takes a shower.
Primer and Joint Compound Issues RIVO Painting 15 07-19-2013 11:47 AM
Paint peeling on joint compound mitchnrobin Painting 10 12-16-2010 06:50 AM
Joint compound? Spackle? Or something else? Amycat Painting 15 06-23-2010 09:16 AM
Use joint compound over grooves in paneling that have already been painted ? lilsis Painting 2 04-01-2010 01:57 PM
Texturing over painted walls l1r Painting 3 08-05-2008 11:52 AM
