Will Ceramic Tile Stick To This? - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-16-2007, 11:12 PM   #1
Will Ceramic Tile Stick to This?
I am remodeling my kitchen and one of the things I would like to do is install a ceramic tile backsplash. I removed some disgusting yellow paneling that was glued to the plaster wall above the counter and I am left with this patchy mess of a wall. Do you think this wall will still work as a substrate for the ceramic tile backsplash if I sand it and fill in the holes with joint compound and smooth it out? Or, should I take the laborious route and cut this section of wall out, and replace it with drywall?
Thanks!
average is offline   Reply With Quote
Old 06-17-2007, 06:22 PM   #2
Rewards Points: 5,336
I would think thinset and a notched trowel should do the trick. Apply the thinset with the flat side to fill in the depressions, then the notched side to set the depth for the tile size.
Ron
Old 06-28-2007, 09:35 AM   #3
What would be the best material to fill the holes and smooth out the wall? Joint compound, floor leveller, thinset, or some other material?
Old 06-28-2007, 12:20 PM   #4
Rewards Points: 774
Ron
Thinset
cibula11 is offline   Reply With Quote
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 06:12 PM
stains on ceramic tile sdgoss Flooring 4 09-19-2008 06:19 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
Ceramic Tile Backsplash Installation DK75 General DIY Discussions 4 11-01-2006 07:56 PM
Ceramic tile installed over resiliant tile ramsfanjeff Flooring 1 11-26-2005 02:26 PM
