Widening Existing Laundry Area Door Opening - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-21-2012, 02:18 PM   #1
Widening existing laundry area door opening
My current washer/dryer sit in a recessed area with a set of bifold doors that are closed when the w/d are not in use. The framed opening is 60"w x 80"h. When the bifold doors are open the opening is reduced to 50" (the combined width of the folded doors). I am going to replace the w/d with front loaders on top of pedestals with drawers. As I need a minimum opening of 54" when the bifold doors are open so the drawers will clear the opening when pulled out, the current opening needs to be enlarged. I have enough room to widen 3" on each side, which will increase the framed opening to 66" and approximately 56" when new 28" bifolds are installed. this will give me about 1" of clearance on each side, close, but I think the 3" on each side is about all I could get. I also need to increase the depth by 2", most of which I could do by bringing the top rail out (1 1/2") and then could use another 1/2 " to be safe. This is an inside wall and the top of the opeining will not be changed. Potential issues, suggestions?
DavidH is offline   Reply With Quote
Old 02-21-2012, 02:53 PM   #2
Rewards Points: 636
is the wall load bearing supporting 2 nd floor or roof
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 02-21-2012, 03:22 PM   #3
No. On 2nd of 3 floors. Believe back wall of laundry area is load bearing but do not plan on doing anything to that. The laundry opening is off a hall with halls perpendicular at either end so the wall/area that I would be expanding ends at the 2 hall openings. Essentially,the laundry area, along wiith a separate closet shares the back of the living room wall. I was just going to remove the trim/wallboard and move/replace the studs that frame the current opening.
Old 02-21-2012, 03:27 PM   #4
Rewards Points: 636
as long as you are sure sounds like you have looked into it
if removing studs just make sure they do not support a header above door
Old 02-21-2012, 03:54 PM   #5
Rewards Points: 77
Sounds good to me, also. Once you widen the opening you could probably just make a new stud wall in front of the opening with new head framing, since you want extra depth, then drywall it all back to new again.
MNsawyergp is offline   Reply With Quote
Outdoor Seating Area JackOfAllTrades Landscaping & Lawn Care 10 02-05-2010 02:01 PM
New Roof and Insulation over Existing Roof MitchellScott Roofing/Siding 1 05-03-2009 08:24 AM
Blending ceiling patch with existing sheet-rock (slight texture) gmhut Painting 3 07-29-2008 11:16 AM
Upstairs Laundry Room Install Matt Burks Remodeling 3 08-21-2007 11:12 PM
help Chuckman Off Topic 8 06-15-2006 10:06 PM
