Widening A Door Frame - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-03-2010, 01:28 PM   #1
Question
Widening a door frame
I had a door leading to my basement that had a cat door cut into it. I was given a door, but I need 2 more inches in the door frame. What advice can y'all give me? I'd love to use the new door, but how much trouble would it be to widen the door frame?
Thanks in advance,
Erich
ErichRhom is offline   Reply With Quote
Old 01-03-2010, 03:17 PM   #2
Rewards Points: 266
is the replacement door solid? It might be easier to make the door fit your frame rather than the other way around.
take the 2" off the door. just make sure you cut it off the hinge side. as if you take any off the doorknob side the backset for the knob will be wrong.
can use the original door as a template to re-mortise the hinges into the replacement door. not to bad of a project. If you need a wider doorway it would be more work as you have to make sure the header that is in place is wide enough.
If you dont need the wider door i would vote to fit the door to the current opening
What have I done is offline   Reply With Quote
Old 01-03-2010, 07:01 PM   #3
Now why didn't I think of that....
Old 01-05-2010, 01:01 PM   #4
Rewards Points: 5,336
Depending on the new doors construction, taking 2" off any one side might not work. With other doors, even taking an inch off each side won't work. It all depends on the doors internal construction.
Widening the rough opening can be simple or complicated depending if the wall is load bearing. Going into the basement would probably be load bearing.
Ron
Old 04-06-2010, 02:32 PM   #5
I have the same issue with a door exiting my kitchen. It takes a 29" door and I want to put in a 32". How close do you need to be to the 34 1/2" rough opening? I think I can easily get it to 34". I would most likely replace the header.
Aikidoka69 is offline   Reply With Quote
Considering widening interior doorway - How difficult? davewolfs Remodeling 11 05-23-2007 01:26 PM
Widening a doorway in a load bearing wall EFEmm Building & Construction 3 03-23-2007 07:17 AM
