-   -   Widen a doorway (http://www.diychatroom.com/f15/widen-doorway-15119/)
Oilerz 01-03-2008 06:57 PM
Widen a doorway
I need to widen a doorway to a bathroom in house with lathe and plaster, so a disabled person can get in with a wheel chair. Can anyone give some tips?
Thanks.
AtlanticWBConst. 01-03-2008 10:35 PM
Found this for you. But bear in mind that the link's tips are for widening a doorway in a NON LOAD BEARING WALL.
Doing any kind of work on a load bearing wall is a different project all together.
Here is the Link for widening a doorway in a NON-load bearing wall: http://www.ronhazelton.com/howto/doorway_remodel.htm
Spike99 01-04-2008 11:43 AM
Lots of great info within: http://www.ahealthyme.com/topic/sraccess2
As stated within this link, "A 36-inch door will often suffice, though I've used a 42-inch door to allow a 90-degree turn into". If possible, go with a wider then needed door opening. When my son was in his wheelchair, I liked the "extra wide" openings the best. Wider the better....
BTW: Specialized bathroom info within: http://www.ahealthyme.com/topic/sraccess3
Hope this helps as well...
Educator 01-06-2008 09:31 PM
Our daughter (early 20's now) uses a walker in the house. We have found a 36 inch door to be the best. It gives her more than adequate room. Any larger a door opening and we would think there would be issues with the door once you try to open it and keep it open. A 42 inch door just seems to take up sooooooooo much more room than a 36 inch door in a room.
Are you considering a pocket door? We love them. Much easier for a physically challenged person to use (ever to open a swing door from a wheelchair? :no: Not very easy.
In the en suite we renovated for our daughter once we bought the house last summer we had build a 'false' wall in order to install a pocket door in both the en suite as well as the wall-in / roll-in closet. Took more time, but well worth it. Now we don't have to worry about what to do with the door when it is open, we / she just slides it into the pocket in the wall.
