Where To Vent Bath/stove? - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-27-2008, 02:54 PM   #1
Enormous Member
skipjack's Avatar
Rewards Points: 87
Where to vent bath/stove?
I'm probably going to be installing a bath fan and a stove vent in the near future. Is there any advantage to venting out the soffit over going straight up through the roof?
Can you vent a stove out through a soffit?
Thanks for any input!
skipjack is offline   Reply With Quote
Old 08-28-2008, 10:46 PM   #2
IM (not so)HO-----see I'm honest..
Bath vent to soffit //yes...one less hole in the roof, performs as well, and cost effective. AL flex duct or plastic should be ok (you might want to check local code).. be sure duct joints are sealed and I would insulate duct ( just to avoid possible condensation problems.)
Kitchen vent: Go to the roof...You want this as straight as possible so you can exhausts as much as possible. If you vent this to the soffit you risk a visible smokey grease trail.. shingles for the most part do fine,,and the junk gets washed away when it rains.
have fun
Big Bob is offline   Reply With Quote
Old 09-02-2008, 01:00 PM   #3
Enormous Member
skipjack's Avatar
Rewards Points: 87
Thanks BB!
Low-Slope Ventilation - Cobra Fascia Vent and Cor-a-Vent Roof-2-Wall vent atulc Roofing/Siding 7 08-22-2008 10:40 PM
Plumbing Vent size recommendations rlhed Plumbing 4 07-31-2008 12:01 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 06:34 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 09:57 AM
