Where Should I Be Worried About Asbestos In My 1910 Craftsman? - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-04-2013, 11:38 PM   #1
Where should I be worried about asbestos in my 1910 craftsman?
I bought a house in Everett WA which was built in 1910. Where should I be worried about finding asbestos? The only obvious remodel that's been done is the kitchen has a drop ceiling with flourescent lighting, and the kitchen and dining room floor have been covered in linoleum looking material (wood-I think fir-floors underneath).
ernestmayhand is offline   Reply With Quote
Old 09-05-2013, 05:59 AM   #2
DIY staff
Rewards Points: 7,174
Your Linoleum--black cutback adhesive---drop ceiling panels--vermiculite insulation--pipe wrapping---siding----this is a short list of possible asbestos containing items from the past.
Old 09-05-2013, 07:32 AM   #3
Rewards Points: 13,300
And then there's the lead paint.
Asbestos and the lead in the old paint under the newer layers is not going to do anyone any harm unless it gets disturbed.
Sanding, cutting, heating them then some precautions need to be taken.
oh'mike (09-05-2013)
Old 09-05-2013, 01:49 PM   #4
Thanks fellas, first thing we're doing is removing all the lathe/plaster upstairs and installing electrical, and then drywalling. I've broken off a chunk of plaster and will be dropping it off at a nearby lab for $35 asbestos test. I also have a piece of insulation from the crawl space which I may have tested as well, but have posted an image in another thread to see if it's identifiable so I can save another $35 for the insulation testing. With the plaster I'm just assuming it's plaster but have seen lots of posts on here where people thing gypsum board is plaster, I don't know the difference I'm a newb.
Old 09-05-2013, 05:19 PM   #5
DIY staff
When demoing an old place like that, get your self good respirators----that old plaster and ancient dust is rough on the lungs-----
Add strong fans to the windows and plastic off the doorways---
Take care of your lungs----
Gymschu (09-05-2013)
Old 09-09-2013, 08:42 AM   #6
Mold!! Let's kill it!
Rewards Points: 2,012
Use N95 rated respirators with P100 cartridges, not those paper dust masks with a rubber band.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
oh'mike (09-11-2013)
Tags
1910 , asbestos , craftsman , lathe , plaster
pulled up the linoleum does it have asbestos? bonniemel Flooring 46 08-07-2016 09:18 AM
Asbestos resources Pt 1 RWolff How To Guides 11 08-01-2013 09:26 PM
Botched asbestos removal in home... runfrombears General DIY Discussions 28 07-31-2012 10:21 PM
Botched Asbestos Removal Several Years Ago...Remediation? vs1988 General DIY Discussions 10 08-17-2010 12:28 AM
Encapsulating old asbestos vinyl tile Familypro40 Flooring 17 03-22-2009 04:20 PM
