Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 03-23-2009, 04:24 PM   #1
They're all fixer-uppers
J187's Avatar
Where should a floor transition
Where exactly should a floor transition? Say, a bathroom or a bedroom to the hallway... How far into the jamb should that rooms floor go, right to the stop?
J187 is offline   Reply With Quote
Old 03-24-2009, 07:36 AM   #2
Not exactly sure what you are looking for...different flooring materials, changing direction, etc. Laminate flooring systems have transition moldings that allow you to go from one room to the next. They are a necessity since the floor floats. Nail down hardwood flooring does not need a transition molding. If there is a door, the transition is usually under the door.
Old 03-24-2009, 07:44 AM   #3
Remodeling Contractor
It should end at the door stop on the hinge side. When the door is closed you should only see the door for that room.
Old 03-24-2009, 09:44 AM   #4
J187's Avatar
Ah, thats what I figured. Thanks.
