Where New Drywall Meets Old. - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-18-2008, 09:29 PM   #1
Question
Where new drywall meets old.
I am in the midst of a bathroom remodel. We're salvaging a floor to ceiling built-in cabinet as well as the ceiling. I've torn out all the plaster/sheetrock except the last 2 inches near the ceiling and the cabinet.
Here's my dilema....the old plaster/sheetrock is approximately 3/4" thick. The thickest greenboard I can find at local home stores is up to 5/8" thick. What is the best way to make these surfaces match?
1.) Build up a "ramp" of the mud and tape to make the difference disappear.
2.) Fasten 1/8" thick furing strips to the studs to the 5/8" will match the thickness of the existing sheetrock.
3.) Something else that I haven't thought of.
I'm actually planning to hire the drywall work out, but want to ensure that the contractor has the best plan/foundation to work on.
Some additional considerations, the door and window frames are obviously well suited for the 3/4" thick walls. The plan is for a tile tub surround which would use a 1/2" Durock substrate. Thank you in advance for your advice!
brneilly is offline   Reply With Quote
Old 02-18-2008, 09:39 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Furr out the existing framing with 1/4" wood strips. Install 1/2" XP board, rather than MR board.
The 1/4" furring strips will also accomodate the 1/2" cement board too.
Try and use a pneumatic stapler or brad nailer when attaching the furring strips to minimize/eliminate splitting of the wood strips.
Link for XP board: http://www.nationalgypsum.com/products/product69.aspx
- Build Well -
Old 02-18-2008, 09:53 PM   #3
Thank you very much for your expertise advice and contribution to these forums!
Old 02-19-2008, 08:59 AM   #4
Woodworker and Contractor
Kingfisher's Avatar
Rewards Points: 150
just like Atlantic said, Use a sheet of 1/4" plywood for the strips and they will not split bad at all. Good luck
Kingfisher is offline   Reply With Quote
Old 02-19-2008, 10:18 AM   #5
Good Suggestion.
- Build Well -
Curved corners where drywall meets? SouthGAreno Remodeling 12 01-17-2013 04:10 PM
Bathroom Drywall jeepwillies Drywall & Plaster 11 05-03-2011 01:04 PM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 04:00 PM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 09:52 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
