Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 02-19-2008, 03:37 PM   #1
Default Where to get bathroom panels similiar to rebath? Side panels?
Our tub is ok but we want to remove the fibreglass enclosure and install side panels similiar to what rebath installs but I don't want to pay rebath since we plan to diy. I like the stone tile look and they have a setup at home depot that I like. My tub is fine so this would just be the 3 panels. I was wondering where I can buy these panels with the stone look just like what rebath sells? Thanks.
twilightcall is offline   Reply With Quote
Old 03-04-2008, 10:52 AM   #2
Originally Posted by twilightcall View Post
.. I like the stone tile look and they have a setup at home depot that I like....
Why can you not buy it at home depot?
redline is offline   Reply With Quote
Old 03-06-2008, 11:19 AM   #3
Bob
Rebath is a outside contractor that has a display at home depot.
Home depot does not actually carry the material, you have to contract with rebath and of course the won't sell you the material alone.
harborbreeze is offline   Reply With Quote
More On This Topic
You can choose many different sizes and styles of glass block for decorating. The block comes in 4- to 8-inch squares and in a variety of smooth, textured, clear, and diffused styles. Before choosing your glass, decide how and where it will be used, so... Read More »
Bathtubs can be dangerous places for those with disabilities. It's important to lay out the bathtub area carefully to provide optimum safety. Depending on your budget and space, there are a variety of modifications that can be made to help insure a safer... Read More »
All right, now that we have everything done and installed, we're going to put the bike back together, and we'll just put this fender back on, just like that. One side, just putting all the bolts back in, to connect the fender. Just make sure you don't... Read More »
Here we are we are beginning to start brushing the debris off of the screen enclosure. The wind is blowing from this side today so I'm going to want to start on this end of it because as any loose stuff gets picked up the wind is going to blow the... Read More »
Hi this is Jon on behalf of Expert Village in this video clip we'll be turning off the water. Now some tubs have an access panel or you can actually reach into the wall and they'll be a shut off valve located in the wall that will just shut off the water... Read More »
Installing Solar Panels on Your Home or Business doctorhouse Building & Construction 6 09-04-2008 11:23 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
