Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 02-18-2013, 10:31 AM   #1
Where to find bifold doors for odd sizes
I Am looking for a set of bifold doors for a pantry but not having much luck. The opening is 40.5" wide. I was hoping to find 2 -20" bifolds but cant find them. HD can special order a set but will be 3-4 weeks and cost 170.00. Do I have any other option?
Maine1 is offline   Reply With Quote
Old 02-18-2013, 01:37 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
if you can find a solid 42" door you can take hte hinges off it and rip 3/16" off all four edges then reasseble it.
another thing you can do is go with the 40" and install a half jamb with 3/4" stock that the door tucks behind which will hide the space
woodworkbykirk is online now   Reply With Quote
Old 02-22-2013, 11:38 PM   #3
Or remove 2x4 jack studs and replace with 1x 4 jack studs
kaschmid3 is offline   Reply With Quote
Old 02-23-2013, 01:32 PM   #4
if its a bearing wall you CANNOT DO THAT there wont be sufficient strength in the wall and you run a major possibility of the door binding up
Old 02-23-2013, 01:44 PM   #5
Thanks for all the replies. I'm not going to make any structural changes so I decided just to buy a special order bifold door set from Lowe's. It will fit the space exactly, it did cost about 140 bucks A little more than I want to spend but I have other projects to do. It will make the wife happy anyway and that's what it's all about.
bifold doors loriel Carpentry 8 06-27-2011 02:21 PM
Input on which doors to replace interior & exterior door with... tomas21 Carpentry 13 12-08-2009 10:32 AM
Installing closet doors into un-true opening - Need ideas McCool Carpentry 8 08-12-2009 02:37 PM
Bifold Laundry Closet Doors? DIYtestdummy Remodeling 2 02-14-2008 03:38 PM
Home Made Closet Doors allen1466 Building & Construction 9 10-25-2007 05:57 PM
