-   -   Where to find bifold doors for odd sizes (http://www.diychatroom.com/f15/where-find-bifold-doors-odd-sizes-172260/)
Maine1 02-18-2013 10:31 AM
I Am looking for a set of bifold doors for a pantry but not having much luck. The opening is 40.5" wide. I was hoping to find 2 -20" bifolds but cant find them. HD can special order a set but will be 3-4 weeks and cost 170.00. Do I have any other option?
woodworkbykirk 02-18-2013 01:37 PM
if you can find a solid 42" door you can take hte hinges off it and rip 3/16" off all four edges then reasseble it.
another thing you can do is go with the 40" and install a half jamb with 3/4" stock that the door tucks behind which will hide the space
kaschmid3 02-22-2013 11:38 PM
Or remove 2x4 jack studs and replace with 1x 4 jack studs
woodworkbykirk 02-23-2013 01:32 PM
if its a bearing wall you CANNOT DO THAT there wont be sufficient strength in the wall and you run a major possibility of the door binding up
Maine1 02-23-2013 01:44 PM
Thanks for all the replies. I'm not going to make any structural changes so I decided just to buy a special order bifold door set from Lowe's. It will fit the space exactly, it did cost about 140 bucks A little more than I want to spend but I have other projects to do. It will make the wife happy anyway and that's what it's all about.
