When Did They Put Asbestos In Plaster? - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-09-2009, 10:46 AM   #1
when did they put asbestos in plaster?
My house was built in 1900. Did they use asbestos in plaster then?
jdix is offline   Reply With Quote
Old 04-09-2009, 11:49 AM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
Yes. They may have. It was more common in areas where asbestos was abundant. It was even used in drywall and drywall compound into at least the 1970s. The only real way to know is to get it tested.
Old 04-09-2009, 02:31 PM   #3
Registered User
Rewards Points: 526
Not only there..............
http://www.epa.gov/asbestos/pubs/ashome.html
Read all the black print before you leave that page, a truckload of info. Be safe, GBR
Old 04-09-2009, 11:49 PM   #4
Tired & Dirty
Rewards Points: 83
they als
evapman is offline   Reply With Quote
Old 04-10-2009, 09:40 PM   #5
Asbestos fiber may have been added to the finish plaster coat..
A little went a long way... a handful asbestos was tossed into the large batch to extend the working time of the plaster. A large room or a slow mechanic might increase the odds of it being used.
only way to know is to have it tested.
Big Bob is offline   Reply With Quote
Old 04-10-2009, 09:49 PM   #6
Learning by Doing
Leah Frances's Avatar
I'd worry a lot more about the lead paint covering the plaster - or flaking off of it. Your plaster may or may not have asbestos - but you MOST ASSUREDLY have lead paint.
BTW - I won't get all trooly on you about the lead paint. Just avoid dry sanding, change your shoes and clothes before you leave the work area, and ABOVE ALL ELSE wash your hands. That's just good general advice anyway.
If I could only remember to THINK about what I was doing before I did it.
Last edited by Leah Frances; 04-10-2009 at 09:53 PM. Reason: one more thought to add
Leah Frances is offline   Reply With Quote
Old 04-11-2009, 06:11 AM   #7
And wear a respirator (N95 or better with P100 filters), not just a cheap dust mask. Asbestos is an inhalation hazard. Lead particles can be an inhalation as well as an ingestion and absorption hazard. Asbestos fibers can remain airborne for weeks or months, while lead particles are fairly heavy and will settle out quickly. Lead poisoning effects are fairly immediate, while asbestos related illnesses will take years to show up.
Vinyl Siding Versus Painting Asbestos freedom_fighter Remodeling 3 02-27-2009 10:35 PM
Plaster Walls - Did I screw up? jamiedolan Building & Construction 5 11-07-2008 12:10 PM
asbestos & paint--let's talk. jaes Painting 4 08-10-2008 10:49 AM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 05:27 AM
Asbestos in plaster? Erebus Remodeling 1 02-15-2007 08:13 AM
