Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 03-27-2007, 05:06 PM   #1
What to use to spray texture on new drywall?
I remodeled my bathroom with all new drywall. All mud and tape is done and I'm ready to spray texture. I want to do a knock down or an orange peel texture. I have a hopper spray gun and I've used powdered aggragate before that you mix with water. The problem I have is keeping each batch consistent.
What can I use that is already premixed? Can I just use the USG all purpose joint compound with the blue or green lid if I thin it down a bit? Any suggestions would be greatly appreciated.
klemmy is offline   Reply With Quote
Old 03-27-2007, 05:58 PM   #2
Master Craftsman
Big Dave's Avatar
Yes you can. We always just used the cheapest mud we could buy and thin it down. You will need to thin it down quite a bit. The thinner it is the easier it will come out of the hopper and the finer the splatter will be. You can also use the smaller hole for an orange peel. If your gonna knock it down you will have to wait about 7 minutes or so before you do knock it down or else you will practically wipe it off the wall. In other words let it set up a little bit.
Do one thing at a time, do it well, then move on.
Big Dave is offline   Reply With Quote
Old 03-27-2007, 06:33 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
To add to Dave's comments - You want to get the mix to a consistency of pancake syrup. If it sits for more than an hour, add a little water and re-mix before trying to use it.
- Build Well -
Old 03-27-2007, 06:43 PM   #4
Master Craftsman
Big Dave's Avatar
I don't like it quite that thin but that's just me.
Old 03-27-2007, 07:46 PM   #5
WHAT? Out first dissagreement on something ....
ok.....I'll tell you that you don't know what you're talking about, then you tell me that I don't know what I am talking about......then, we will take it from there....!!
J/K
- Build Well -
Old 03-27-2007, 08:23 PM   #6
Contractor
I use PVA primer from Home Depot to thin my mud so that when I paint it usually only takes 1 coat.
Sliraq is offline   Reply With Quote
Old 03-27-2007, 09:20 PM   #7
ok, I have 2 gallons of the premixed usg mud with the blue lid and about 2 gallons of the usg with the green lid. Will one work better than the other? My bath is only about 8x8 so I dont think I'll need much but I think I'll use more than 2 gallons so I wasnt sure if I could mix them or what?????
Old 03-27-2007, 09:26 PM   #8
Master Craftsman
Big Dave's Avatar
Sure, go ahead and mix them together. It won't hurt a thing. Be sure to mix them first then thin to desired consistency. It's gonna be painted anyway.
Old 03-27-2007, 11:16 PM   #9
i just sprayed knockdown and i used the all purpose green lid JC. Thinned it down to pancake batter consistency and sprayed it at approx 30-40 psi. Came out pretty good. Good luck
sflamedic is offline   Reply With Quote
Old 03-28-2007, 07:37 AM   #10
AH hah...That's what I meant to say...'Pancake batter'.... consistency.
(I accidently wrote: 'pancake syrup' )
- Build Well -
Old 03-28-2007, 09:00 AM   #11
Great, thanks for all the help. Now I need to find a tile forum to figure out why my brown grout looks white in some spots. I bought some grout haze cleaner but I still cant get the grout to look brown when dry. You guys have any experience with this?
Old 03-28-2007, 09:07 AM   #12
I saw him using "Yogurt"... now "Pancake Syrup".... just see if I learnt my Pyscology 101 right....
AtlanticWBConst: am I right if I guess you are someone who spent quite a lot on delicious food ....
KUIPORNG is offline   Reply With Quote
Old 03-28-2007, 10:28 AM   #13
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Poor mixing is usually the culprit.
Brik is offline   Reply With Quote
Old 03-28-2007, 10:30 AM   #14
Handyguy
Brik's Avatar
BTW - Do you guys read all those posts about how to make a wall smooth?!?! We give advice on how to make it rough AND how to make it smooth. If it were me I wouldn't texture a wall. Thats just me.
Old 03-28-2007, 10:37 AM   #15
Up here in Wisconsin, most people use knockdown or orange peel texture. I would have went with smooth walls, except my house is ancient and this bathroom was made up with 3 generations of walls so it was a real chore to make everything look neat and square. I feel better knowing I can spray some texture on the walls to hide any imperfections that I missed.
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 04:38 PM
Spray Texture Piney Painting 4 03-02-2007 01:24 PM
Texturing drywall patch? Doug Crf Remodeling 4 09-21-2006 08:54 PM
Repairing dry wall and matching texture? Doug Crf Building & Construction 1 08-17-2006 04:50 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
