-   -   What to use to spray texture on new drywall? (http://www.diychatroom.com/f15/what-use-spray-texture-new-drywall-7397/)
klemmy 03-27-2007 05:06 PM
I remodeled my bathroom with all new drywall. All mud and tape is done and I'm ready to spray texture. I want to do a knock down or an orange peel texture. I have a hopper spray gun and I've used powdered aggragate before that you mix with water. The problem I have is keeping each batch consistent.
What can I use that is already premixed? Can I just use the USG all purpose joint compound with the blue or green lid if I thin it down a bit? Any suggestions would be greatly appreciated.
Big Dave 03-27-2007 05:58 PM
Yes you can. We always just used the cheapest mud we could buy and thin it down. You will need to thin it down quite a bit. The thinner it is the easier it will come out of the hopper and the finer the splatter will be. You can also use the smaller hole for an orange peel. If your gonna knock it down you will have to wait about 7 minutes or so before you do knock it down or else you will practically wipe it off the wall. In other words let it set up a little bit.
AtlanticWBConst. 03-27-2007 06:33 PM
To add to Dave's comments - You want to get the mix to a consistency of pancake syrup. If it sits for more than an hour, add a little water and re-mix before trying to use it.
Big Dave 03-27-2007 06:43 PM
I don't like it quite that thin but that's just me.
AtlanticWBConst. 03-27-2007 07:46 PM
WHAT? Out first dissagreement on something ....
ok.....I'll tell you that you don't know what you're talking about, then you tell me that I don't know what I am talking about......then, we will take it from there....!!
J/K :wink:
Sliraq 03-27-2007 08:23 PM
I use PVA primer from Home Depot to thin my mud so that when I paint it usually only takes 1 coat.
klemmy 03-27-2007 09:20 PM
ok, I have 2 gallons of the premixed usg mud with the blue lid and about 2 gallons of the usg with the green lid. Will one work better than the other? My bath is only about 8x8 so I dont think I'll need much but I think I'll use more than 2 gallons so I wasnt sure if I could mix them or what?????
Big Dave 03-27-2007 09:26 PM
Sure, go ahead and mix them together. It won't hurt a thing. Be sure to mix them first then thin to desired consistency. It's gonna be painted anyway.
sflamedic 03-27-2007 11:16 PM
i just sprayed knockdown and i used the all purpose green lid JC. Thinned it down to pancake batter consistency and sprayed it at approx 30-40 psi. Came out pretty good. Good luck
AtlanticWBConst. 03-28-2007 07:37 AM
AH hah...That's what I meant to say...'Pancake batter'.... consistency.
(I accidently wrote: 'pancake syrup' :bangin: )
klemmy 03-28-2007 09:00 AM
Great, thanks for all the help. Now I need to find a tile forum to figure out why my brown grout looks white in some spots. I bought some grout haze cleaner but I still cant get the grout to look brown when dry. You guys have any experience with this?
KUIPORNG 03-28-2007 09:07 AM
Psycology test
I saw him using "Yogurt"... now "Pancake Syrup".... just see if I learnt my Pyscology 101 right....
AtlanticWBConst: am I right if I guess you are someone who spent quite a lot on delicious food ....
Brik 03-28-2007 10:28 AM
Poor mixing is usually the culprit.
Brik 03-28-2007 10:30 AM
BTW - Do you guys read all those posts about how to make a wall smooth?!?! We give advice on how to make it rough AND how to make it smooth. If it were me I wouldn't texture a wall. Thats just me.
klemmy 03-28-2007 10:37 AM
Up here in Wisconsin, most people use knockdown or orange peel texture. I would have went with smooth walls, except my house is ancient and this bathroom was made up with 3 generations of walls so it was a real chore to make everything look neat and square. I feel better knowing I can spray some texture on the walls to hide any imperfections that I missed.
