Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 01-04-2007, 10:44 AM   #1
What type of mud to be used for a wet Wet banjo
I have spent $50 canadian bucks on a wet banjo.... hoping it would be helpful... but after reading the message from the contractor forum.... I suspect I probably end up not able to use it due to difficulties consider I have yet to try my first knife of mud...... anyhow... for me to test run it.... what type of mud should I use? All purpose ready made, drying type, setting type...? or doesn't matter...
Thanks...
KUIPORNG is offline   Reply With Quote
Old 01-04-2007, 12:13 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Thanks...
Just use all purpose ready mix in the 5 gallon bucket.
Mix it with about 1 to 2 cups of water.
Use a heavy duty drill with a plaster mixing paddle. (I believe HD carries the paddle). Clean paddle after using it.
If the mix sits for a day or more between uses, add water and re-mix.
You want to get it to the consistency of yogurt. That allows the paper tape to flow easily, as you pull it out of the banjo.
- Build Well -
Venting of Cathedral Ceiling on Shed type roof sandyman720 Roofing 7 08-02-2007 11:27 PM
what type of coating for flat roof kenny357 Roofing 5 06-25-2007 05:47 PM
Comment on those Special Type of Treated Wood for Deck ? KUIPORNG Landscaping & Lawn Care 4 07-04-2006 01:38 PM
Type L Or M Copper Pipe bobo Plumbing 1 11-20-2005 08:53 PM
