What Type Of Morter To Use Under Bathtub? - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-04-2008, 06:46 AM   #1
When is fishing season?
CowboyAndy's Avatar
What type of morter to use under bathtub?
I have to pull my tub out to support it as the person who installed it had to level it, and it sits about an inch off the floor, making the middle totally unsupported. My plan is to put down 6 mil plastic (so the morter isnt directly on the floor in case it ever needs to come out) under and on top of the morter.
The question is what type should I use? What consistancy should I mix it to? Should I fill the tub with water while it is setting?
Thanks.
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 06-04-2008, 08:16 AM   #2
K&B Remodeler/Tile Guy
angus242's Avatar
You could use spray foam. Actually, there are new tubs that come with foam blocks attached to the bottom for support. Just make sure the tub has water in it before you spray and that the foam isn't going to go places you don't want it to!
Angus
My Albums
angus242 is offline   Reply With Quote
Old 06-04-2008, 10:54 AM   #3
CowboyAndy's Avatar
I thought about sprayfoam, but I am worried about it losing its rigidness over time...
MY HOUSE OWNS ME!
Old 06-04-2008, 11:09 AM   #4
angus242's Avatar
Polyurethane foam will support it. It's more of a question of whether or not you can actually get a low-expanding foam in all the places it needs to be.
I would be careful. You don't want to use a thinset. Cement would be the best option. I believe thinset can actually shrink some so you may end up with a small gap under the tub
I'd say foam or cement.
Don't worry about long term, roaches and polyurethane will be around longer than we will!
Angus
My Albums
Old 06-04-2008, 04:28 PM   #5
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
I have used "sand mix" mortar. Mixed to between peanut butter and pancake mix consistency. I built little cardboard dams to contain it and keep in from going where I didn't want it.
Brik is offline   Reply With Quote
Tiling over a bathtub lip The Kid Remodeling 19 02-04-2012 11:46 AM
Refinishing bathtub or installing new one? gante General DIY Discussions 7 06-23-2008 02:54 PM
Need help with Type T and TL fuses? Fotoguy Electrical 6 03-04-2008 01:08 PM
Help with ID'ing bathtub sound... DIY-Gal Plumbing 12 02-10-2007 05:45 AM
