What Type Of Molding Should I Use For My Basement Stairs? - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-26-2011, 08:16 AM   #1
what type of molding should i use for my basement stairs?
I currently have a finished basement with laminant wood flooring. The stairs leading down to the basement are wood and I am planning to stain them but there are a couple small holes between the actual stairs and the drywall. I want to use molding to cover the holes and give a finished look but I'm not sure what covering is best suited for it.
cannonjl is offline   Reply With Quote
Old 07-26-2011, 06:49 PM   #2
Drywall contractor
Rewards Points: 1,070
A picture would help. Is there a skirt board between the steps and the drywall??
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 07-26-2011, 08:19 PM   #3
Stair pictures
Old 07-26-2011, 08:35 PM   #4
DIY staff
Rewards Points: 7,174
Can you see under the stairs? It might be easiest to remove the treads and risers and add a skirt board if the stringers are far enough away from the framing.
Old 07-26-2011, 08:54 PM   #5
Framing Contractor
Rewards Points: 112
No moulding is going to hide that cable running up and under the top tread. A skirt could still be installed now, but it will be a pain.
sixeightten is offline   Reply With Quote
Old 07-27-2011, 10:37 AM   #6
Drywall contractor
Yep, pull the treads and risers and add a 1"x skirt board....
The Following User Says Thank You to bjbatlanta For This Useful Post:
joecaption (12-15-2013)
Old 07-27-2011, 02:28 PM   #7
Rewards Points: 5,336
I'd just caulk the gap. Blue tape the wood and latex caulk it. Then paint it the same color as the wall.
Ron
B. Franklin 1759
Old 12-14-2013, 08:37 PM   #8
Home Depot or lowes sells shoe molding that can be stained. Perfect for these steps
uofmrocky is offline   Reply With Quote
Old 12-14-2013, 09:12 PM   #9
Ole Wood Worker
BigJim's Avatar
Rewards Points: 186
I don't think the fellow is coming back, he made only 2 posts since 2011.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 08:40 AM
Concrete Basement Stairs excaliburleo723 Building & Construction 2 06-17-2011 03:49 PM
Devil in the Details: Molding, Stairs, and Tile to Carpet moodwaffle Flooring 4 04-04-2011 03:23 PM
water comes down basement walkout stairs carriepartlan Building & Construction 1 07-09-2009 07:13 PM
I need a cover for my outdoor stairs to basement. retiredcats Building & Construction 3 04-02-2009 07:09 AM
