-   -   what type of molding should i use for my basement stairs? (http://www.diychatroom.com/f15/what-type-molding-should-i-use-my-basement-stairs-112004/)
cannonjl 07-26-2011 08:16 AM
I currently have a finished basement with laminant wood flooring. The stairs leading down to the basement are wood and I am planning to stain them but there are a couple small holes between the actual stairs and the drywall. I want to use molding to cover the holes and give a finished look but I'm not sure what covering is best suited for it.
bjbatlanta 07-26-2011 06:49 PM
A picture would help. Is there a skirt board between the steps and the drywall??
cannonjl 07-26-2011 08:19 PM
Stair pictures
2 Attachment(s)
Attachment 35852
Attachment 35853
oh'mike 07-26-2011 08:35 PM
Can you see under the stairs? It might be easiest to remove the treads and risers and add a skirt board if the stringers are far enough away from the framing.
sixeightten 07-26-2011 08:54 PM
No moulding is going to hide that cable running up and under the top tread. A skirt could still be installed now, but it will be a pain.
bjbatlanta 07-27-2011 10:37 AM
Yep, pull the treads and risers and add a 1"x skirt board....
Ron6519 07-27-2011 02:28 PM
I'd just caulk the gap. Blue tape the wood and latex caulk it. Then paint it the same color as the wall.
uofmrocky 12-14-2013 08:37 PM
Home Depot or lowes sells shoe molding that can be stained. Perfect for these steps
BigJim 12-14-2013 09:12 PM
I don't think the fellow is coming back, he made only 2 posts since 2011.
