Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 01-31-2012, 09:15 PM   #1
What are these wooden wall/ceilings called? And how to remove ceiling?
See the reference photos. Ignore the water stains (used for another thread post), and you can see part of the wall from these ceiling photos too.
http://dlshare.s3.amazonaws.com/temp/ceiling1.jpg
http://dlshare.s3.amazonaws.com/temp/ceiling2.jpg
The ceiling and wall are made of wood (or wood-like material), not drywall. This is from an old mobile home. I was wondering what the ceiling material and wall material is called. Does it have some trade or technical name to refer by?
Let me know if I post to wrong forum to ask this type of question.
The ceiling appears similar to some commercial building ceilings where the ceiling is divided into square pieces and are textured with a pattern like the photo, the difference is in the photo/mobile home, the ceiling is one long rectangle broken up by the dividers and not square. And unlike the commercial ceilings, don't seem to be able to lift up (easily, at least) to see what's up in the "attic" area.
So the related question is, how to lift up / remove the ceiling, other than breaking it apart?
daluu is offline   Reply With Quote
Old 01-31-2012, 09:22 PM   #2
It's just cheap paneling. Most likly it will be distroyed when removing it.
It can not be lifted and there is no attic in a mobil home.
Old 01-31-2012, 09:28 PM   #3
KemoSabe
loneframer's Avatar
That is most likely a mineral fiber product. I've seen it in many mobile homes. It is attached to the framing members, not installed in a track system.
http://www.armstrong.com/commceiling...r-ceilings.jsp
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
The Following User Says Thank You to loneframer For This Useful Post:
mae-ling (01-31-2012)
Old 01-31-2012, 10:49 PM   #4
MarginallyQualified
if you think that looks bad...
wait 'til you see what it was put up there to hide!
Old 02-01-2012, 11:46 AM   #5
I agree with Loneframer. Chances are the ceiling and walls are glued and maybe stapled to the wall structure and are an integral part of the structural strength of the mobile home. If you try to remove it, it will come out in pieces. Why do you need to see behind it?
mrgins is offline   Reply With Quote
Old 02-01-2012, 03:22 PM   #6
Thanks for the info.
Don't want to tear it apart or see what's behind it. Just wanted to know what the material is called (out of curiosity).
And for the ceiling, wanted to know if it was removable or not.
Because one may wonder how to repair these things if a wall or ceiling went bad (or say have leaks stain or mold, and a cleanup + paint job doesn't look very good still). It would suck if fixing part of wall or ceiling either meant tearing up and redoing the room/wall/ceiling w/ drywall instead or using same material to replace in whole, because I'm guessing you can't patch it like drywall holes and cracks, especially if as mrgrin says it's glued and nailed down permanently.
