What Size Recessed Light Do You Prefer? - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-09-2011, 06:21 AM   #1
What size recessed light do you prefer?
We need to decide on which size recess lighting to use for our kitchen and living room. Our kitchen is 10 x 15 ft (those tiny California ranch house built half a century ago, thus the tiny kitchen ), living room is 26 x 15 ft.
larger sizes such as 6" will be more efficient in illumination. However, both me and my wife think those 3" or 4" looks a lot better. We are pretty neutral to either one now.
6" not good looking, but bright
3" good looking, but not bright.
thus, I'd like to see what you guys think. What size cans do you put in your kitchen and living room?
htabbas is offline   Reply With Quote
Old 11-09-2011, 06:29 AM   #2
Busy DIYer
picflight's Avatar
Rewards Points: 150
Combination of 6" & 5".
picflight is offline   Reply With Quote
Old 11-09-2011, 07:30 AM   #3
They all have a place. It depends on what you are lighting. Most lighting manufacturers have a selection guide somewhere in their catalog.
Old 11-10-2011, 08:33 PM   #4
Ironlight's Avatar
Larger light offer better general illumination, while smaller ones provide more localized light. While the bigger lights are...bigger, you'll need fewer of them to achieve the same amount of light.
I think it is really a matter of what character of lighting you want rather than what you want your ceiling to look like.
I'm redoing our kitchen/dining/family room right now and I've put in 6" lights through out and a few smaller eyeball wall washers. I wanted more light and fewer lights.
Ironlight is offline   Reply With Quote
Old 11-11-2011, 07:55 PM   #5
don't get 3" or 4". Way too dim. They are meant for accent lighting, not so good for general lighting. My friend has 4" in his kitchen and living room. I took a look at his setup for ideas when I did my renovation. He regrets getting such small lights. I had the same dilemma as you. I like the look of smaller lights. I ended up using 5" in the kitchen, 6" in the living room. It is much much better. Put dimmers on it, and you have the option of dimmer light when you want it.
For what's its worth, I did use 4" around the perimeter of the dining room to light up the walls. It complements the center chandelier over the table.
acerunner is offline   Reply With Quote
Old 11-13-2011, 02:20 PM   #6
Too Short? Cut it Again!
Depends on what kind of light source. Small halogens give off lots of light and are a fraction of the size of fixtures that hold more traditional bulbs. I think the canisters look more in scale with small kitchens. Heat is the issue to a point.
Have you looked at "wire type" track lighting? The wires almost disappear. The lights float on the track wherever you want them.
Old 11-13-2011, 04:33 PM   #7
In a little over my head
Rewards Points: 706
I just had to make the same decision. I ended up with 6". More light, more trim options, and the cans cost less.
ratherbefishing is offline   Reply With Quote
Old 11-14-2011, 08:15 PM   #8
Rewards Points: 5,336
The size of the can is secondary to the amount of light the room needs. The smaller the can, the lower wattage bulb.
Ron
B. Franklin 1759
Old 11-15-2011, 09:04 AM   #9
Careful. A tiny low watt halogen will kick out as many lumens as some large incandescent floods.
Please recommend a small recessed light for accent/gen use RickDel Electrical 7 03-27-2012 02:23 PM
Wire recessed light from a 3 prong receptacle? prc114 Electrical 9 12-22-2009 10:29 AM
Recessed light in stairway rubicon789 Electrical 9 02-25-2009 02:21 PM
Remodel style recessed light code question bjstewa Electrical 8 05-22-2008 10:25 PM
Recessed light plan foiled? kcrossley2 Electrical 8 03-15-2007 12:08 AM
