What Size Header Should I Use? - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-25-2010, 03:08 PM   #1
what size header should i use?
i want to open up my kitchen wall. just a 5x3 hole somewhere in the middle. i know it's a load bearing wall, what size header should i use?
jakejr13 is offline   Reply With Quote
Old 07-25-2010, 06:46 PM   #2
Registered User
Rewards Points: 4,902
Depends on the load above: http://ftp.resource.org/bsc.ca.gov/t...2_page0376.pdf
Be sure the add blocking in the floor under the required number of jack studs to the beam or wall below.
Be safe, Gary
Gary in WA is online now   Reply With Quote
Header Size Seyamr Building & Construction 5 01-28-2010 12:13 PM
Garage door header size Bogey0345 Carpentry 12 11-29-2009 07:21 PM
What size header is needed.... mulhollendm Building & Construction 2 11-18-2009 03:34 PM
Header size question BimmerRacer Carpentry 18 03-01-2009 08:51 PM
Header size for wall opening firebirdbd Building & Construction 1 08-07-2007 06:11 PM
