What Is The Recommended Order For Doing These Upgrades? - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-12-2008, 12:47 PM   #1
Question
What is the recommended order for doing these upgrades?
We are going to be updating our living room and bedrooms in the coming months but I'm trying to figure out the order of operations.
Here are the things we are going to do
Can Lights (Living Room & Hallway)
Windows (Living Room & Bedrooms)
Paint Walls & Ceiling (Living Room, Hallway, and Dining Room)
Hardwood floors (Living Room, Hallway, and Dining Room)
Carpet (Bedrooms)
Baseboards (Living Room, Hallway, Dining Room, and Bedrooms)
Input is appreciated.
tomas21 is offline   Reply With Quote
Old 08-12-2008, 01:01 PM   #2
Registered User
Termite's Avatar
I'd do the electrical and windows first. Then paint. Then carpet. Then I'd have the hardwood installed and finished. After that is done, then I'd install the baseboard and base shoe.
My logic is to protect the new floor materials by getting as much done as possible before they go in. Paint touch-ups will probably be required after everything is done (sweat marks, scratches, etc).
Old 08-12-2008, 07:10 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Can Lights (Living Room & Hallway) - Do first, if ceilings are damaged, they can be fixed before painting.
Windows (Living Room & Bedrooms) - (Do also before painting). If walls are damaged, they too, can be fixed prior to paintwork.
Carpet (Bedrooms) - Do prior to hardwood in areas listed below. Why? - The carpet-installer-traffic, etc, will be going thru the homes main areas to get to the bedrooms. New hard wood flooring, "could" get "roughed-up".
Hardwood floors (Living Room, Hallway, and Dining Room) - Do after the above, but before baseboards.
Baseboards (Living Room, Hallway, Dining Room, and Bedrooms) - Install after hardwood, to allow required hardwood flooring expansion gaps, against walls, to be hidden.
Paint Walls & Ceiling (Living Room, Hallway, and Dining Room) - Do last. Why? When installing floors, carpet, etc...your walls and ceilings - WILL (this is a fact), - be banged up with dents, gouges, scrapes, etc.
If you paint prior, you will be spackling, priming, and repainting ALOT of areas, all over again. Paint walls and ceilings last, using drop clothes or craft paper effectively.
Paint baseboard and moldings prior to installation - "Touch them up" after.
- Build Well -
Old 08-13-2008, 08:43 AM   #4
my way:
lights
windows
hardwood(tape cardboard down to protect, hold people accountable)
baseboards & I would shoe the hardwood as well
paint
carpet(I don't like to do too much painting over carpet...especially ceilings)
dhag is offline   Reply With Quote
Old 08-13-2008, 01:27 PM   #5
Originally Posted by dhag View Post
my way:
lights
windows
paint
The rooms that will be getting carpet have already been painted about 4 months ago. The rooms getting painted will be the ones getting hardwood floors (Living room, dining room, and hallway).
I appreciate everyone's input!
Old 08-13-2008, 06:11 PM   #6
In that case, paint the hardwood rooms first, but still be prepared for dings and dents to touch up.
- Build Well -
Old 08-13-2008, 07:23 PM   #7
So your updated order would be this? Out of curiosity why would you recommend painting the hardwood floor rooms first?
1. Can Lights (Living Room & Hallway)
2. Windows (Living Room & Bedrooms)
3. Carpet (Bedrooms)
4. Paint Walls & Ceiling (Living Room, Hallway, and Dining Room)
5. Hardwood floors (Living Room, Hallway, and Dining Room)
6. Baseboards (Living Room, Hallway, Dining Room, and Bedrooms)
Old 08-13-2008, 09:18 PM   #8
I am sorry, I did not mean to state that you should do them "first" (before other areas). What I meant is, that you should paint those rooms prior to the hardwood flooring install. When ever you can "group" work together (to be done at the same time)... You save money (if hiring out) and you save time (Both: if you are hiring out, and also if you are doing the paint work yourself).
In this context; if the walls in the rooms to have hardwood floors, are painted first, you will be able to get the "brunt" and "scope" of the paint work done, prior to the flooring install.
That means that the majority of the paint splatters will be "splashed around" before the flooring is installed.
Now, on the other hand, when the flooring is installed, as stated earlier, you will, MOST DEFINTELY, have gouges, dents, and dings. However, you can put a drop clothe down, and take care of these areas, even after the flooring is in.
Maybe I "miss-spoke" from a GC stand point when I stated to "paint last"...simply because we have painters to be able to lay out "floor-coverings" and perform the required spackling (touch-up) and paint...and it is no big deal...from our perspective.
From a DIY standpoint, it would seem better to paint first...then do the touch-ups after.
- Build Well -
Old 08-14-2008, 07:53 AM   #9
Thanks for the clarification... I'm going to be hiring out the entire job so it looks like I should group the jobs together to maximize time & save some money (Can lights, windows, carpet), then (paint), then (hardwood floors), then (baseboards), and then (touch-up paint). I may do the windows myself and prep work on the walls but we will see.
Installing tile and wood- what order? red shoes Flooring 7 05-08-2008 05:34 PM
Need help with permit/city got a Stop Work Order. amdspitfire General DIY Discussions 39 02-07-2008 02:45 PM
What order 4 bst results shotdown Painting 6 06-27-2007 09:19 PM
