What Is A Properly Ventilated Bathroom? - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-12-2014, 02:47 PM   #1
Rewards Points: 24
What is A Properly Ventilated Bathroom?
Hi
What is considered a properly ventilated bathroom? I have a ventilation fan, but after a shower the walls are soaked. Is a properly functioning fan supposed to keep the room dry?
kc27 is offline   Reply With Quote
Old 02-12-2014, 03:01 PM   #2
Rewards Points: 736
Originally Posted by kc27 View Post
Hi
There's a good chance your fan is working fine, but there's nowhere for it to pull air from. Learned this myself. An exhaust fan can't pump out more air than the room can pull back in (a dinky little exhaust fan isn't going to turn yoru bathroom into a vacuum... ). Find some way for fresh air to come into the room as well as for the wet air to get out, and you'll be fine.
TheBobmanNH is offline   Reply With Quote
Old 02-12-2014, 05:06 PM   #3
MarginallyQualified
Rewards Points: 2,464
An open window works incredibly well.
As noted by BobMan... it's about air movement (changes).
If the room is 7'x9'x8' (504cu ft)...
even the simplest and least expensive 50CFM exh fan will give you a complete change in 10 minutes... if it has air to change.
Old 02-12-2014, 05:41 PM   #4
Rewards Points: 12,868
There's suppose to be a 1" gap under the door so the fan is not a creating negative pressure.
It would be like sucking on a straw with your finger over the tip.
Why open a window and let in cold air? It would work, but the room would get colder.
Old 02-12-2014, 05:48 PM   #5
Rewards Points: 2,512
Hi
No typical residential bath exhaust fan will completely expel all the moisture laden air from the room before SOME of it has had a chance to condense onto a cooler surface like windows and even walls.
Have you made sure that the vent to the outside is not plugged??
hammerlane is offline   Reply With Quote
The Following 2 Users Say Thank You to hammerlane For This Useful Post:
bhawleyusa (02-12-2014), Windows on Wash (02-13-2014)
Old 02-14-2014, 05:46 AM   #6
Typically the shower walls will be wet after a shower. My three shower walls always are and the glass door.
Columbus Ohio Basement Full Bathroom -Post-Construction Compliance Hermi14 Plumbing 5 03-12-2013 08:11 PM
Rewiring Bathroom & Den heyjoe91 Electrical 4 02-21-2013 05:22 PM
bathroom exhaust connected to 26' of duct ChrisJJ HVAC 1 01-31-2013 11:50 AM
gutting bathroom debiasio Remodeling 30 02-17-2011 03:32 PM
Bathroom fan replacement reveals...a mess merlanvp Electrical 0 07-25-2010 09:00 PM
