Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 05-21-2011, 09:35 PM   #1
What is the proper way to cut CBU around windows
I've been reading and searching and still can't figure out the best way to go about putting cbu around my window.
I was wondering what is the proper procedure to cut CBU/Durock around windows opening. The windows size is 3x3 feet, and the wall size is 4'4" wide x 8' tall.
Should I cut 2 3x5 board of CBU in half and install it vertically. This will leave a joint in the middle top/bottom of the windows and no joints in the corners.
Should I install the board horizzontally . This will create a joint on both middle sides of the windows.
Or should just cut the CBU to fit propery on the sides, top, bottom. This will leave joint in the 4 corners.
I'm aware of proper installation of drywall (use a full sheet and fit the windows inside the drywall), but cant find any info on internet for cbu .
Note: the window is in a dry area.
avtck is offline   Reply With Quote
Old 05-21-2011, 10:32 PM   #2
Super Moderator
Treat it the same as drywall--avoid seams in corners of the window---
Old 05-22-2011, 07:27 AM   #3
If the window is in a dry area, why the cement board?
Ron
Pella Windows - Serious Frost Issue snowman72 General Discussion 22 07-08-2011 01:39 AM
Wood Sash to Vinyl Replacement Windows Pittsville Building & Construction 3 05-27-2011 03:24 AM
replacing windows.. modifying a rough opening by less than 2 inches? diy'er on LI Building & Construction 14 09-18-2010 07:43 PM
are these windows installed correct? michelleb Building & Construction 7 08-20-2010 05:36 PM
Co. installing my impact windows measured all wrong. Now they want to "rig" them in. heydade General Discussion 45 10-10-2009 04:44 PM
