Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 02-12-2009, 03:56 PM   #1
What to leave open for inspection?
I picked up electrical and building permits for my remodel. The building inspectors wants to come by for only the final, before I put on the tape and mud on the drywall. My biggest issue is with the electrical inspector: I'm going to have entire spots where I can't hang drywall because I'm needing to keep the area open for electrical inspection. Is the inspector going to want to see exactly how I've attached the boxes, nailed the wire to the stud, etc? Or can I just put up the drywall and leave the wire hanging out? I have a full basement where you can trace all the wire back to the panel. Bare drywall is ugly, but a room of mixed drywall/bare insulation is even worse. I'd rather be able to just hang the drywall, call it done and move to the next room.
forkvoid is offline   Reply With Quote
Old 02-12-2009, 04:07 PM   #2
Xtreme DIY'r
Where I am the electric inspection is seperate & before any insulation or sheetrock is installed. Better make sure
Old 02-12-2009, 04:08 PM   #3
Chicago, IL
Michael Thomas's Avatar
Odd. Around here their is always a pre-closeup and a final inspection.
Michael Thomas is offline   Reply With Quote
Old 02-12-2009, 04:15 PM   #4
The problem with going that route is that I'm doing the entire house. That would leave me a house without any insulation or drywall at all until the entire thing was ready for inspection.
I spoke to the building inspector and he said he didn't want to waste my time with anything but a final inspection, since I'm not changing any framing or anything of the sort. I can't get hold of the electrical inspector(his voice mail says he only answers his phone between 8am and 8:30am Monday through Friday; he also does not return calls). How I routed the electrical wires, there's absolutely no reason to inspect anything but where the electrical is. Typically, there's two or three studs to either side that are open currently for his inspection.
Old 02-12-2009, 06:06 PM   #5
Xtreme DIY'r
Building Inspector can do what they want
Since the structure is existing the main issue is if you use the proper insulation
But electric is a whole nother ball game
They usually want to see rough 1st, then the final
Old 02-12-2009, 06:57 PM   #6
What constitutes a rough in? Just installing boxes or running cable but not hooking into the panel? Final would be installation of the sockets and hooking into the panel?
Old 02-12-2009, 07:05 PM   #7
Xtreme DIY'r
Rough for us is boxes installed, wire run, wire coming out of the boxes ready for devices/outlets/switched
I was told to have the neutrals & grounds landed = no hots
Not sure if that is how it is everywhere
Old 02-12-2009, 08:06 PM   #8
Okay that's what i have right now. I just want to know if they need to see the wires between the box and the subfloor.
Old 02-12-2009, 08:30 PM   #9
Xtreme DIY'r
I have wire running along the floor joist - 2nd floor
I cut the piece of plywood, but its not secured in place
So that can be opened for inspection
But in my sunroom I had the subfloor down - since the walls were built on top of the sub-floor. It wasn't a problem
Its up to your Inspector on what they want
Not sure what others maybe have encountered?
Old 02-12-2009, 09:09 PM   #10
Learning by Doing
Leah Frances's Avatar
Set your alarm clock and get up and CALL THE INSPECTOR AND ASK HIM. The electrical inspector in your jurisdiction is the only one who knows the answers to these questions.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 02-12-2009, 10:29 PM   #11
I've been trying. It goes to voice mail. He does not return calls. I suspect the only time I'm going to see him is when I schedule an inspection through the main office.
Old 02-12-2009, 10:53 PM   #12
If he is a good inspector and does his job, he will want to see all of your work, BEFORE it is covered up.
A good inspector will look closer at a homeowners work than a professionals work, because the HO usually don't know what they are doing.
bwalley is offline   Reply With Quote
Old 02-13-2009, 11:23 AM   #13
Newbie Bill
Can the main office give you a guideline as to what stage the inspector wants to see?
If not I would just schedule an inspection and see where it goes.
drtbk4ever is offline   Reply With Quote
Old 02-13-2009, 04:09 PM   #14
Drywall contractor
Again, it's based on where you live. In the various counties in the metro Atlanta, electric is generally inspected before insulation. Some counties after, but all before drywall.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 02-13-2009, 04:13 PM   #15
I was able to get hold of another inspector for the city(but still cannot get hold of the one I was assigned). He said since I'm doing an entire house, they are willing to come out multiple times to do rough-in and final of sections of the house, instead of the entire house at once(which would leave me with a house with no electric). I've already got one room insulated and mostly drywalled, except for the portions where electrical is. I'm not going to insulate any other rooms until I have him come out and do a rough-in, at which point I'll get more specifics of what he will allow me to do.
Thanks for your responses, guys.
Open Stairs in Basement ngerhard Building & Construction 4 07-10-2009 07:30 PM
Which should open first GFCI or breaker jamiedolan Electrical 14 01-19-2009 04:03 PM
Stop a door from drifting open? Sliding Man Carpentry 17 11-16-2008 04:18 PM
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 10:39 PM
garage door open light deck hand Electrical 3 01-22-2008 09:29 AM
