Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 05-07-2010, 11:00 AM   #1
Knows everything but that
What kind of wood for interior wall?
Im putting in a non-load bearing wall to surround a three wall alcove bathtub. Im a bit overwhelmed by all the choices of 2x4s at the stores and dont trust the ones that work there to give me good advice. So... What should I buy? Thanks!
Shane
JakAHearts is offline   Reply With Quote
Old 05-07-2010, 11:44 PM   #2
Just regular Kiln Dried, #2 or better. Species doesn't matter a lot. SPF (spruce, pine, fir) is common but you might find DF (Douglas Fir) or Hem F (Hemlock fir). Those are all fine.
Old 05-08-2010, 12:07 AM   #3
In my house, anything that sees moisture (like bathrooms and doorframes) gets pressure treated wood. It gives an extra bit of protection and bugs won't eat them if you live in a termite zone.
kindrox is offline   Reply With Quote
Old 05-08-2010, 02:29 AM   #4
Wire Chewer
Red Squirrel's Avatar
Actually is there any reason NOT to go with PT lumber for indoors? I was thinking of doing this for my basement. 2x4 footer/header and studs all PT.
Is there any codes against that perhaps in case of fire? (toxic fumes)
Old 05-08-2010, 08:39 AM   #5
Inspectors have never said boo about it. I have never used them as a header but don't see why it would be a problem.
Old 05-08-2010, 02:58 PM   #6
One problem with using PT in that manner is the twisting and bowing of the PT as it dries out. Ask me how I know! Methinks that a better method is to use standard studs with a proper vapor barrier to prevent water or moisture from getting to the wood. For bottom plates, though, I believe PT to be an excellent idea.
Too, with the newer PT formulations, one has to be careful to use the proper fasteners...I think it requires HOT dip galvanizing or stainless steel.
rod
RoyalAcresRod is offline   Reply With Quote
Old 05-08-2010, 07:09 PM   #7
Lots of deck screws say they are good fot pressure treated. I've never used them as studs in a long wall or something.
Old 05-09-2010, 07:27 AM   #8
Super Moderator
Yikes-----Use regular studs---Pressure treated studs will twist and bow as they dry!!!
The studs had better not be a wet area when you are done. Just build the shower correctly in the first place.
PT studs are not allowed on interior construction except when in direct contact with concrete.
That's code here---likely where you are ,too.----Mike---
Old 05-09-2010, 02:58 PM   #9
Handyman
That kind of makes sense Mike...if, God forbid, the house caught fire imagine the toxins that would be released. Up here it is also illegal to burn PT wood in fireplaces, etc. just for that reason.
canadaclub is offline   Reply With Quote
What To Prime Wood With to Accept Joint Compound? Lovegasoline Building & Construction 19 11-03-2009 06:04 AM
Been looking at some Wood Burning Stoves SELLC HVAC 17 10-20-2009 10:06 PM
what kind of wood is this? Knucklez Carpentry 31 05-05-2009 10:20 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
Add-on wood furnace in a small house? Jim Dam HVAC 1 06-24-2008 02:48 PM
