Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 03-25-2009, 11:17 PM   #1
What kind of wall for tiling bathroom and shower
I am in the process of tiling the entire bathroom of ours. It currently has a 4 piece tub (3 walls+tub) and we are going to replace the tub because it squeaks. We are also going to eliminate the acrylic walls or whatever material it is and place tile there.
It is my understanding that you pull the tub out and walls, install 1/2" cementboard to the studs and fiberglass tape everything up. Once you apply the fiberglass tape what do you cover it with?
Also, the rest of the bathroom is covered with drywall and we want to have tiled walls. Do we need to remove the walls or can we tile on top of the drywall with some kind of surface prep? The drywall is currently painted. Does greenboard enter the picture?
Any help would be great.
This is a picture of the bathroom, kinda hard to get a good pic.
ghostdog is offline   Reply With Quote
Old 03-26-2009, 06:17 AM   #2
In the shower I use a product by Schulter, called Kerdi. It's a water proof membrane that gets applied with unmodified thinset. Then you tile on top of this.
For the non wet areas, I would just tile on the existing drywall as long as the walls were straight and plumb.
Ron
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 10:11 AM
Tile in Shower and on Wall of Bathroom jwhiteuwc General Discussion 2 02-02-2009 09:21 PM
Bathroom wall tile Ricksweares Flooring 10 02-26-2008 04:16 PM
Shower / Bathroom Install xlr8tn Plumbing 1 01-15-2008 05:08 PM
Bathroom Shower Help - PLEASE :) OTEJUNK Remodeling 5 05-09-2007 11:33 AM
