What Fill Around Mudroom Support Posts? - Remodeling - DIY Chatroom Home Improvement Forum
Poll: What do you think of using pressure treated wood in the ground for support posts?
Poll Options
Old 08-13-2009, 06:05 PM   #1
Question
What fill around mudroom support posts?
I'm replacing some rotten support posts under our mudroom (formerly a porch, that someone enclosed years ago), which sits 3-4' above ground. After I've replaced the supports we will be regrading the yard, filling in that area 3-4' deep and covering the new posts.
http://gallery.me.com/ramatsu#100123...&bgcolor=black
1) I'm pouring footings on top of untouched ground, but I'm concerned about lateral support from the fill. I won't have room to get a compactor around the posts underneath the mudroom. Should I fill that area with gravel or other rock-based product for sufficient lateral support?
2) I'm torn between using pressure treated posts (attached to galvanized saddles set in the footers) vs. concrete tube pillars. I'm not a big fan of creating problems for someone 20 years down the road when the pressure treated posts need to be replaced. If the answer to question 1 is "use gravel or rock," digging out those posts could be a real nightmare. But the tube pillars are more work and money.
Any thoughts would be very welcome!
ramatsu is offline   Reply With Quote
Old 08-14-2009, 12:53 AM   #2
Renovation Contractor
Paragon's Avatar
Rewards Points: 150
What does local building code dictate?
James D. Van Raden
Owner, Paragon Renovations Moorhead, MN/ Fargo, ND
"Committed to providing the finest renovation services available"
Paragon is offline   Reply With Quote
Tags
concrete block wall , fill , grading , posts , support
8' x 12' deck how - many support posts needed shuanrit Landscaping & Lawn Care 5 07-09-2009 10:57 PM
How to replace wood support posts under main beam webjanet Building & Construction 1 09-07-2008 11:15 PM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 05:24 PM
Replacing covered porch support posts yousah Remodeling 4 09-30-2007 01:15 PM
Support posts for 12' high deck hotchkiss Remodeling 3 09-05-2007 07:32 PM
