What Do I Do Next? Tub Installation Question - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-27-2014, 09:21 AM   #1
Question
What do I do next? Tub installation question
I am still at my rookie run at a total bathroom remodel project but have come across a dilemma on order of sequence
All demo work is done and have exhaust fan / electrical & ceiling installed
I planned to install walls next and have purchased hardi-backer board for shower / tub area but reviewing instructions & video etc... they indicate that board should be installed 1/8 inch above tub and floor but I have not installed tub yet and have not laid flooring -
I was going to do floor near the end but now am unsure??
Any ideas to move project forward?
Also when installing new tub should I install a hardi-back layer on sub-floor prior to setting tub in place or can I set on wood floor (that is how tub I removed / original was installed)?
oiler39 is offline   Reply With Quote
Old 04-27-2014, 09:35 AM   #2
Rewards Points: 14,020
Tub is set on the subfloor. Make 100% sure the tub is installed according to the manufactures directions and sits level in both directions.
You did buy one with a lip around the three edges, right?
Tub is set before tile board goes in on the walls or floor.
Have you checked to see if the floor joist, subflooring meet the specs for tile?
Just keep the tile board up a little from the underlayment, you do not have to account for the tile thickness, tile is run up to the wall leaving a gap for expansion.
Old 04-27-2014, 10:54 AM   #3
OK thanks for your response Joe
I do have a tub with 3 edges and will work on the installation of tub next
I have not purchased my flooring materials yet - so when you say make sure the sub-floor / floor joists meet specs for tile?
where is this information found?
Also your comment "keep the tile board up from underlayment" do you mean the tile board should have a space / gap between tub and / or floor tiling?
question on foam board installation ROB62 Insulation 3 05-09-2012 11:28 PM
Question regarding my tub Installation noviceshock Plumbing 1 02-19-2012 01:33 PM
new door installation question mrs fix it Windows and Doors 10 12-04-2011 08:19 AM
SubPanel Installation Question lowvolter Electrical 7 12-01-2011 06:17 PM
Installation of Granite Tile On Shower Walls Spacing Question. taras1 Building & Construction 2 08-04-2010 11:48 AM
