What To Do About An Old Flue? - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-31-2009, 10:55 AM   #1
What to do about an old flue?
I am in the process of insulating the unfinished portion of my basement. I currently have a natural gas forced air furnace, however there are traces of an old heating system in the basement. There are two flue entrances that are not in use. Can I simply insulate over these, or should I seal them somehow first?
My method of insulation is attaching R-10 rigid codeboard insulation to the foundation wall with adhesive, then building a 2x4 wall in front of the codeboard and filling it with R-12 batt insulation.
Any help would be appreciated.
jord1981 is offline   Reply With Quote
Old 05-31-2009, 12:16 PM   #2
Rewards Points: 5,336
My definition of a flue, is a pipe that enters the chimney. Is that what you're referring to?
Ron
Old 05-31-2009, 01:21 PM   #3
Essentially yes, though the pipe has been long since removed. I am referring to the hole through which the pipe used to go to reach the chimney.
Old 05-31-2009, 04:18 PM   #4
What you would do depends upon whether the flue is being used or has been abandoned.
If still active, I would get the proper sized cap for the hole and plug it up. Then you would caulk the perimeter with a high temp caulk or furnace cement. If inactive, you could put an insulating material inside that was not combustable.
Ron
Old 05-31-2009, 05:56 PM   #5
Thanks. In addition to the flue hole, there are two holes with doors that I would assume are soot clean outs - do I need to do anything special with these? Pictures attached.
What to do about an old flue?-dsc01211-clean-out-door.jpg   What to do about an old flue?-dsc01212-clean-out.jpg   What to do about an old flue?-dsc01214-clean-out-interior.jpg
Old 05-31-2009, 07:17 PM   #6
Is there anything else using that flue?
Ron
Old 05-31-2009, 07:52 PM   #7
There is a fireplace upstairs, but it uses a separate flue in the same chimney.
Old 05-31-2009, 10:19 PM   #8
Then I would cap the unused flue at the roof to keep out water, wind and animals.
You can insulate the flue entrance in the basement and seal it up.
Ron
Old 05-31-2009, 10:40 PM   #9
Thanks kindly for the advice.
Old 06-02-2009, 06:13 PM   #10
What do I do with the two clean outs? Insulate and build over as well?
Old 06-02-2009, 06:48 PM   #11
Isn't one of the cleanouts for the fireplace? What do you mean by, "build over"? The abandoned cleanout can be sealed if you want. You can also insulate if you want.
Ron
Old 06-02-2009, 06:55 PM   #12
I am insulating the basement and building a 2x4 wall over the foundation wall - these clean outs would end up behind the wall.
Exterior Flue Enclosure Repair edge10 General DIY Discussions 6 08-03-2009 09:15 PM
Capping/removing gas flue destroyer427 HVAC 6 04-05-2009 12:35 PM
How to Space Water Heater Flue Vent from Outside Wall? austinbirdman Plumbing 1 03-12-2007 11:28 AM
Flue Gas Piping and Proper Drafting DK75 General DIY Discussions 2 01-12-2006 10:04 AM
Wood Burning FP needs flue extension Renee Building & Construction 1 08-29-2005 06:26 AM
