What To Do About Crusty Walls? - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-06-2007, 09:11 PM   #1
What to do about crusty walls?
I'm fixing up a tiny room and I just put in the floor, but now the walls look absolutely...crusty. The walls are very rough and bumpy and the lumpy holes resemble miniature potholes. I'm not kidding, it's bad. I wasn't sure if it would be all right to simply spackle over them with masonry spackle or something that adheres correctly. Would the spackle eventually crack off after a couple years, because I would have to put it on rather thick. Any input??
HomeImprover is offline   Reply With Quote
Old 06-06-2007, 09:43 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Crusty?
Never heard a wall described that way before...
Not sure exactly what you mean, but, just get a small 1 gallon bucket of joint compound and skim coat over the holes wit ha 6" putty knife. Let dry, sand lightly..... re-coat, dry, light sand.......do it a third time if necessary.
- Build Well -
Old 06-08-2007, 11:36 PM   #3
Rewards Points: 5,336
It would help if you mentioned what the walls were made of. Is this a basment concrete wall?
Ron
FINISHING BASEMENT WALLS - Cinder Block Walls tmacwith Building & Construction 4 12-06-2012 08:26 AM
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 07:22 AM
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
bowing walls - repair? elementx440 Building & Construction 26 03-04-2009 03:07 PM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 05:33 PM
