What Is The Best Way To Cut Aluminum - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-25-2007, 07:11 PM   #16
I bought a $10.00 right angle grinder at Northern Tool. With a metal cutoff disk it cuts metal angle no problem- with a masonry blade it cuts tile and 1/2" thick pavers, even cuts circles! The cutting disks are about $2.00 ea.- get the thin cutting disks- not the 1/4" think grinding disks
ray dixon is offline   Reply With Quote
Old 11-26-2007, 10:13 AM   #17
Thanks everyone, here is my plan of attack:
- I saw a 10" aluminum cutting blade, but it costs 80 bucks. too much
- I saw a 3 1/2" aluminum cutting blade, it costs 10 buckss, I am going to try to use those for some of the cut with my Makaita cordlesss tile saw.
- I try the angle grinder with metal blade, but this is ok for steel, but I really suspect it will work for aluminium... as the method it used is kind of to melt the metal rather than really cutting it.... and the wound is not that great...
- so for large object, I am going to try to get a 10" plastic cutting 10" blade
- for precision cut and I don't want to loss material, going to use hand saw....
thanks....
KUIPORNG is offline   Reply With Quote
Old 11-26-2007, 11:25 AM   #18
Rewards Points: 150
Quality woodworking carbide will munch through aluminum just fine. Thing is, qualty carbide costs. The 80T 10" Forrest Chopmaster on my radial arm, and 40T Ridge Carbide TS2000 in my tablesaw slice aluminum very nicely. of note, however - when cutting thin stuff - less than 1/8" - it is best to clamp aluminum between wood blocks.
One low-cost option is to use a 7.25" circular saw blade. HD sells a $15 Freud Diablo 40T blade that should work very well in your tablesaw - and it has a very thin kerf. It also works fine in a radial arm, but no idea how it'll fare in a miter. I usually install it when I need a thin kerf.
Oh, aluminum can also be routed with carbide router bits.
scorrpio is offline   Reply With Quote
Old 11-26-2007, 11:30 AM   #19
Rewards Points: 150
Oh, and do NOT use anything designed for steel to cut aluminum. Soft aluminum will load the abrasive, cause it to overheat and fly apart.
Old 11-26-2007, 11:42 AM   #20
Yes, use circular saw with the 7.5" aluminum blade I bought seems a good idea .... gee.. there is so many ways to do the same thing... so I don't need to refund the thing then.... there goes 15 bucks less to spend in Christmas...Thanks...
actually you said mounting 7.5" on a table saw... gee... never thought of that... that is even better... thanks a lot....
I didn't and won't use angle grinder with metal blade to cut the aluminum... as I feel somthing wrong with that combination by instinct anyway...
so I should be all set now...
Old 11-26-2007, 03:47 PM   #21
47_47's Avatar
Rewards Points: 44
Aluminum extrusions is all my company sells and we use a 12" Forrest Miter Master with 80 teeth. You could use a laminate blade with a negative rake do not run the blade backward. Never use a grinding or abrasive cut off wheel, the aluminum will clog the pores and the wheel could explode. Use a wax stick (candle wax) lubricant between every few cuts will help to dissipate heat and prolong blade sharpness. Be careful when using the table saw. Most blades travel around 3500 RPM and small cut offs will become missles.
47_47 is offline   Reply With Quote
Shredding Aluminum Cans bobo General DIY Discussions 36 11-10-2009 03:32 PM
Aluminum wire? Which outlet to use? papashaq Electrical 6 08-27-2007 06:36 PM
Aluminum Door sill and Concrete Dragon Building & Construction 2 01-06-2007 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
