What Is The Best Glue For Plastic? - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-01-2012, 08:28 AM   #1
Rewards Points: 105
What is the best glue for plastic?
Hello,
I ordered new floor speakers and they both arrived with broken removable front covers. The cover frame made from some cheap plastic and plastic frame on both covers is broken in many places. I would like to glue broken peaces together, so I can use the covers. Is it possible? Is there any good glue for my task?
In my former country I used some special chemical/glue which melts plastic. After applying such glue and putting together two pieces the plastic became one intact piece.
sukhenkoi is offline   Reply With Quote
Old 03-01-2012, 08:32 AM   #2
Tom Struble's Avatar
Rewards Points: 2,002
it really depends on the plastic,some can be solvent welded some can't
Tom Struble is offline   Reply With Quote
Old 03-02-2012, 06:41 AM   #3
Rewards Points: 105
Can you tell at least one or two?
Old 03-02-2012, 07:29 AM   #4
the Musigician
DangerMouse's Avatar
You could go buy a small can of PVC/CPVC clear glue at your local hardware store (plumbing dept.) and try it on a small piece. That might be the ticket for your problem since the plastics are similar, but of course, maybe not.
Model airplane glue might work. 2 part clear epoxy would probably do it as well.
DM
To Glue or Not To Glue denvermatt Carpentry 9 08-22-2011 09:21 PM
carpet glue pfmartin0387 Flooring 1 10-03-2010 08:17 PM
do i have to remove old adhesive glue on wall for new ceramic with glue? Limit54 Tiling, ceramics, marble 2 03-01-2010 10:12 PM
glue to a mirror Leprichon Interior Decorating 9 04-19-2009 02:16 AM
Wood Glue Issue gp1200r Carpentry 4 02-20-2008 11:56 AM
